In advance, I advise that everything you see here is intended to be *temporary*, for the purpose of the experiments.
For permanent installation, I would have better brackets and power connection.
As requested, here is how I set up the engine bay auxiliary cooling fan.
I purchased a Davies-Craig 8" thermatic fan.
I saved $23 by buying the no frills fan-only kit, without relay or wiring loom.
Mainly because at this stage I had no clue as to how I was going to power it, or how permanent it would be.
DCSL8 INCH SHORT (12 VOLT) PART No: 0135
UNDER THE HOOD
Because I had a Growler CAI fitted, I had some spare space immediately aft of the Growler, where the old air-box had been.
I used a spare mounting bolt on one side, and one of the canister clips on the Growler itself on the other side, together with some nuts & bolts left over from another project, and 2 brackets left over from a HKS (cheapo Hong Kong) earthing kit, to mount the fan. I had to be careful to keep it clear of the engine, and certainly wasn't going to mount it to any part of the engine, because - you know - engines vibrate!
Pic 1
P4130077a_zps86673bd4.jpg Photo by routier1642 | Photobucket
I mounted it in this position to try to draw hot air away from the air-box and air tube, blowing it out of the cavity at the bottom of the engine bay.
It also served to remove hot air from the engine bay generally when stationary, and blew on the passenger side of the engine block, helping cool that as well.
This last benefit was reflected in the decreased coolant temperatures, and lack of coolant overheat when stationary. It seems to have been more successful at the secondary aim than the primary one.
The Davies-Craig fan was used in its default configuration as a "pusher" fan, intended to be attached to the front of a radiator.
I don't know if this was the most efficient way to set it up, but it did keep the blades facing in a relatively safe direction.
This shot shows the power connection (as well as the dodgy brackets).
Where it almost touched the Growler, I added some rubbery adhesive insulation material (which you can also see on the aircon plumbing). This made contact with the fan, stabilising it, and gave the fan a bit of soft energy-absorbing suspension in case it vibrated in travel.
I made sure that the bolts were tight and that the fan had very little movement on the brackets. I didn't want it making vibration noises or - worst case - vibrating loose and bouncing around the engine bay.
The right hand bracket is actually using cable ties to attach to the fan. This is because I didn't have a bracket of the correct angle. They seem to work well, and will be OK in the short term.
Now for electricity:
Amongst my piles of useless junk, I found a 12VDC car power adapter for a laptop computer. This easily handled the 5 Amps that the fan draws.
You could easily purchase something similar, just make sure it can handle 5+ Amps. I just happened to have this one handy.
At the moment, the wires are just taped into the 12V laptop supply plug. I looped the wires in a knot around the strut brace so that they couldn't pulled loose from the other end.
The next step will be to replace the plug with spade connectors, insulated with heat-shrink tubing, and incorporate the thermal switch.
Pic 2
P4130078a_zpsf7aa91e3.jpg Photo by routier1642 | Photobucket
At the moment, the wires actually go outside the car & back in through the passenger door crack.
This is a small risk, but it's only for a few days.
The next step is to put the wires through a hole in the firewall rubber grommet that you can see just behind the strut top in Pic 1.
I'll need to remove the glove box to get to this from the other side, so I haven't done it yet.
IN THE CABIN
Using the car's internal power adapter socket (formerly known as cigarette lighter socket) had several advantages.
1) I didn't have to worry about a separate fuse or relay, or overloading another circuit. (socket is rated at 15A)
2) Because the plug is in the cabin, I have complete control over the fan and can connect or disconnect it manually at any time.
3) The biggest advantage was that it was controlled by the ignition. Ignition off = fan off.
I have ordered a cheapo Chinese multi-socket with individual switches (eBay can be useful for this stuff), so that I can just flick a switch.
I could conceivably fit a speed control as well, but I don't think it will be necessary.
Pic 3
P4130079a_zpsafc80485.jpg Photo by routier1642 | Photobucket
Looks like I need to vacuum the car again!
The 240V board you see on the floor there is connected to the inverter at the back of my Adventra, plugged into the 12VDC socket in the rear.
I use brick adapters plugged into 240V to recharge the Android tablet I've incorporated into to the console, and to recharge phones, since I found through experience that an ordinary USB connector from an adapter in the 12VDC socket couldn't supply enough current to prevent the battery draining if the GPS and/or wireless and/or Bluetooth is on all the time. It seems odd, going from 12VDV to 240VAC back to 12VDC to get an advantage, but it works really well. And I have the convenience of being able to run small 240V appliances without adapters. I really should move that power board off the floor, though.
DISADVANTAGES
The only real disadvantage of the fan is that it makes a clearly audible whine, noticeable when you're stationary.
ADVANTAGES
Ideal for stop-start driving, such as in heavy or city traffic!
The advantages are that by decreasing heat soak, it:
1) Keeps intake temperatures from rising so quickly when stationary
2) keeps the engine coolant temperature from rising quickly when stationary. Today, after I did a run where both the weather strip and the top radiator shroud were removed, when I stopped, it even stabilised the coolant temperature at relatively cool 93 degrees, which was pretty impressive. The effects do vary a lot, though, and I wouldn't guarantee it being able to do that under all circumstances.
3) Has a small cooling effect when moving at moderate speeds.
Overall, I think it's proving itself worthwhile, and I'll probably work on making it permanent.
