VZ misfire need help
blackvz
In short, #2 misfire
Replaced
Coil and test
Plug
Cleaned fuel system from filter to injectors
Checked all connections and hoses
No change
Pulling hair out
MACE
Hi blackvz
In addition to what you've already done, I would probably do a fuel pressure test to make sure each cylinder is receiving adequate fueling at the right time and if that's all good, I would do a compression check as one of the valves or head gasket may be worn. You may even have a vac leak around the manifold and predominantly that cylinder. Alternatively, I'd hit up the guys on the VZ forum:
VZ Holden Commodore (2004 - 2006)
Kind regards
Damian
