Vz sv6 misfire
vycommy1997
New Zealand
Vy acclaim
How are you checking the volts? Multimeter isn’t ideal for assessing battery health. The charge circuit should also be assessed.
Battery world can do that for you.
Low voltage can easily throw data signals all over the place as the ECM gets irregular data.
As for the ticking, it’s an odd one. Get the rocker/cam covers off. Inspect it all as best you can.
You could have a loose rocker under the cam or a worn valve seal causing some play.
Yes using multimeter, when I have reds on and turn lights on and heaters on I get traction lights flashing, abs, airbag fault. And volts go down to about 8.5 my understanding is that there isn't enough current in the battery and probably needs replaced?
Fu Manchu
WA.
Multimeter won’t tell you if the cold cranking amps are too low, internal resistance and if any of the cells are faulty.
yes the voltage drop is suss.
Mild surface corrosion across all the engine bay harness earths is expected now these cars are getting on. Go through all of them with a small brass brush or similar to clean them up and remove any minor corrosion from threads and surfaces.
Poor harness earths will also create gremlins.
vycommy1997
New Zealand
Vy acclaim
Battery replaced and is good now, car going again I decided to try some 100 octane fuel from npd here in NZ as it has cleaning additives blah blah and it seems to run a lot better but still the odd hiccup, so I've put it down to dirty injectors or something similar
krusing
Melbourne, Bayside
The other thing to check,
Is the multi pin plug/socket for the injectors, which is located under the side of the manifold, at the back on the LHS,
It has a RED slide lock to release it,
Check the pins/connects, clean them with contact cleaner of similar,
And when connecting them back up again, make sure the slide lock is in all the way to secure the connection.
PS: recently I had all of the LY7 manifold off to replace the thermostat and heater pipe o-rings, (did it from the top) a few weeks ago,
since then I have had one cyl 6 misfire, and that was last week, but I am putting it down to the cold, as I hadn’t driven it for 4 days,
But after about 30 seconds of idling rough, it had warmed up, and the miss disappeared, and has been running perfectly the past few days.
lout
60
Langwarrin Victoria
8.5 volts on reds is way too low
try unplugging the 2 wire plug underneath the abs module
and repeat test
