Seanyb100
Hi all. I've recently changed the timing chains on our V6 ecotec VZ. Was running well afterwards but wasn't getting correct oil pressure. Dropped the sump to check and it was the mandatory blocked pickup. I've cleaned it all out now, put the engine back together and now the engine won't prime the oil through to the pump. Is there any way to externally prime the oil pump on one of these engines, or am I back to ripping the sump off again to prime it up?
