VZ - V6 4 Speed Auto issues
VB Owner
VB and VX Berlina
Hi All,
Currently working on a VZ V6 2006 Model. 4 Speed Auto.
With the transmission there is no error codes on the scantool.
When starting off it will rev to about 3000rpm before changing to 2nd. Does the same in each gear.
Any clues why this can be ?
Fluid levels are spot on, just havent changed it yet.
lout
60
Langwarrin Victoria
check pedal throttle sensor
VB Owner
VB and VX Berlina
Oh ? That will cause this issue ? I just noticed when ignition is on and unplug the harness, there is no click ?
