VZ V6 pcv valve squealing
Wildrx3
47
VZ V6 Ute
Hi all,
I have recently cleaned my pcv valve in my alloytec and i now have a squealing noise if i remove the hose from the intake manifold it stops if i put my finger over the hose it starts again and if the engine is above about 2k rpm it also stops. Is the pcv hose supposed to have suction as i thought it was supposed to vent from the rocker cover it has suction .Any assistance would be appreciated .
stick3
newcastle nsw
vz sedan vs ute gsx1400
Hi all,
did you do the mod by drilling it out
heres the howto thread https://forums.justcommodores.com.au/threads/vz-and-ve-alloytec-pcv-problem-fix.279039/
Fu Manchu
WA.
Remove it again, put red thread sealant around the base and reinstall it.
It might have gone out of round depending on how you removed it. Could have been a bit heavy handed.
It will be a small leak between the cover and the PCV.
krusing
Melbourne, Bayside
Get it smoke tested to see if you have any vac leaks, which could possibly cause the noise/whistling.
Wildrx3
47
VZ V6 Ute
Thanks guys will try removing it again and sealing it again
