Revhigh
Dandenong South
Holden VF Maloo
August update
- We can now supply GENUINE TIMING CHAIN KITS as well on our website.
Please select Genuine kits when checking out, or request a Genuine Timing Kit install when dropping off your vehicle.
Timing Chain Kits available to suit the VZ VE VF 3.0 and 3.6L LY7, LEO, LU1, LLT, LFX, LFW and LF1 motors.
http://www.revhigh.com.au/timing-chains-v6-alloytec-sidi-36l
We can install this kit in Dandenong South VIC starting from $999 including parts and labour!! $90 for replacement oil/coolant or supply your own!
Book an install before October 30th 2019 for a free set of gears!! use the code GEARS99.
We only sell top quality parts that we use in the workshop!
3 year parts warranty
1 year labour warranty
What your kit includes
  • 1 X Genuine timing cover gasket kit
  • 2 x Genuine Rocker Cover Gaskets
  • 1 X Genuine Premium steel timing chain guide
  • 3 X Genuine heavy duty timing chain tensioner
  • 1 X Genuine Improved production timing chain Primary
  • 2 x Genuine Improved production timing chain Secondary
  • 5 X Genuine Precision diecast aluminium timing chain guide
If you are unsure if this suits your vehicle leave message or leave the following information in the notes section and we will supply the correct kit.
- Year Build Date
- Month Build Date
- Make and Model info
Please be aware on some early VZ variants the lower guide attached to the oil pump is not a direct swap with the one in our kit, you will either need to replace the oil pump *recommended" or reuse your old lower guide. We can supply the oil pump in a package price, please message us.
These kits do not come with the Idler/Crank Gears, if you require these or VVT/VCT Cam phaser gears please message us for a quote.
Basic fitting service including kit $999.
For package deals on replacement or performance parts please dont hesitate to contact us.
Location.
REVHIGH
20/73 Assembly Drive
Dandenong VIC
3175 Australia
0415##546##361##
Revhigh
Dandenong South
Holden VF Maloo
Book before the end of October and quote the code GEARS99 via ##0415##546##361 for a free set of Genuine GM gears installed on any VE-VF Timing Chain install built after Aug/2006!!
Revhigh
Dandenong South
Holden VF Maloo
scaredyet
Mosman
Holden VZ Lumina Wagon
Can you guys also clean up the sludge in the engine and also remove the sump and clean the pick up as well while you got everything open
Revhigh
Dandenong South
Holden VF Maloo
Yes we can. To drop sump, sonic washing, replace oil pickup o'ring we usually charge $200-$250!
Suami
2017 SSV Redline
Just wondering if you guys have a genuine throttle body and throttle position sensor complete for a 2010 VE 3.0V6 ? While we are at it for the same vehicle:
Differential
Coil Pack
Much Appreciated
rtmpgt
33
Perth, WA
www.pgt.design
2010 VE1.5 SV6 Ute
Glad to see the price of timing chain installs dropping through the floor.
Used to be a good $3k to do it.
Revhigh
Dandenong South
Holden VF Maloo
Pricing has gone up guys :( $1250 not but includes an oil pump!
dat111
umina beach,nsw
VS commodore
do you know anybody in the newcastle/sydney area who does it ?
