VZ Won't crank after reverse battery
rhysu
Australia
VZ Tonner
Hey guys, I signed up since everyone of the threads i was reading from here had mixed results due to different causes making the same symptoms... anyway, I got a VZ ute for nothing if I can fix it and the story is the previous owner put a new battery in and connected it the wrong way for a split second before realising what he had done after the sparks flew at him. He left it for a bit and reinstalled the battery the correct way (he is old mind you and sight is not the best)
The ignition turns on and all the interior accessories work, lights, windows, stereo, instruments etc but it won't crank. No ticking, no drain of power etc. I put my OBD2 connector on it and connected to the ecu fine but pulled up no fault codes after scanning it twice.
At the same time it is reading "Fuel Gauge Error" and "Service Vehicle Soon". All the fuses have been checked and all relays replaced with working ones from other vehicles I own.. Yet still a mystery.
Was wondering if anyway was able to shed some light on it at all.
CONROD
SOMEWHERE in the land of OZ
VZ SS THUNDER 6.0l 6 Sp
Have you checked the fusible links in the fuse box under the bonnet. If think not having the ignition on has saved everything from sudden death that's why its all still o.k
illlusion
VE SSV MY10
Bcm probably fried you will need to relink the bcm with ecu if you get another one or it won't work tech 2 or similar will be needed to make the link up
rhysu
Australia
VZ Tonner
Yeah checked the fusible links in the fuse box. They're all perfectly fine.
rhysu
Australia
VZ Tonner
Enough to start.. Wouldn't stop it from cranking though....
vc commodore
Like the Leyland Brothers
VC, VH and VY
Have you checked you're getting power to the starter solenoid, when trying to crank? If not, check for power to and from the relay, and the fuses, starting from the solenoid area, back to the ignition switch....
If you're getting power there, under cranking, good chance the starter is fried....Replace the starter and you should be good to go.
Trayner
Fresh prince of Pakky, Gangsta
Gangsta Hundy
Ground wire at the back of the engine , at the back of the passenger side head . or starter is dead
Eevo
SA
VY SS Ute
manually bridging the starting will tell if its working
