Vz Wont Go Over 4k Rpm
Holden vz
Ve Berlins
hey guysz
need help today i installed a sub in my car everything was fine until i switched the car on,the trac control turned off and my service reminder came up,then when i drive its really slow and wont go over 4k rpm ,ive installed subs before but not sure what has gone wrong could i have cut a wire? ,i checked all the fuses,last resort will be take it to an auto elec
routier1642
64
Australia
2005 Adventra LX6
There is a 4K RPM limitation when in Park; maybe you cut a wire or accidentally disconnected a plug or did something that is fooling the ECU into thinking that you are still in Park?
Maybe retrace your steps and look for open circuits.
Or maybe something upset the ECU. You could try resetting the ECU; you might get lucky.
Holden vz
Ve Berlins
i tried resting the ecu had no luck ,could find any damaged
wires either hmmmm
routier1642
64
Australia
2005 Adventra LX6
Tried plugging in an OBD scan tool & checking for error codes?
Holden vz
Ve Berlins
yeah got nothing,im gonna get a auto elec to have a look at it tomorrow
Holden vz
Ve Berlins
turns out i cut a wire for a sensor under the gas pedal
