accentstencil
- Jun 30, 2005
- 8,376
- 587
- 113
- Age
- 71
- Location
- Caboolture South, QLD
- WH II Caprice, 5.7 2018 Equinox LTZ V
My daughter's car has a problem that I can't get to the bottom of, it will often stall, but nearly always when going down a slight hill with a sweeping left hand bend. It will often happen at the same place over and over again. When it stalls you can put it in neutral while still rolling and it will start again no probem. This is quite dangerous because you lose power steering and I worry that she will have an accident and she is usually carrying a baby and young child.
There are no fault codes and we have rounded up the usuall suspect, fuel pump, fuel filter and CAS, all changed. This problem has been going on since they bought the car about six months ago.
The only thing I can think of that it could be is a loose wire that fails when pointing down a hill and veering left.
I would appreciate and opinions on what could be causing this.
