what did you do to your car today?
uniacidz
Harden the Frak Up
Sideneee
VE Berlina
Went for a long walk as part of my off day in my exercise routine
Got home and got in car and did the same route which turns out to be 4.86 kms via trip meter thing
Took it for a drive afterwards and still gives me a smile driving her.
Oh and blinded some moron coming towards me with his high beams on. :)
Sent from my HTC Aria using Tapatalk II
CAPRILICIOUS WL
WL CAPRICE
Decided it was time I change my leather caprice steering wheel that was faded, to a Vz leather Calais wheel.
Did the entire job in an hour. :)
LS1 James
Donates His Member
39
Andrews Farm, SA
VT II GEN3 V8 Wagz
New Water Pump and Compression test :)
imrhoss
1996 VS Statesman, 2013 VE II SV6 Thunder Ute.
Smoked up a burnout in my street then parked it
Sent from my GT-I9100 using Tapatalk 2
drewVHSS
Donating Member
Gosford Central Coast
stores.ebay.com.au
'83 VH SS, '79 Green VB SL '92 S2 VQ Caprice
VQ:
climbed through the boot again thanks to the door lock deciding to go into "deadlock" mode again.
replaced the filler neck coupling hose (this would wanna be the last of the fuel leaks dammit)
stuck a 2nd hand greenfoam memcal in and took her for a tunerpro logged drive (thanks dirb for the ecu, well worth what i paid for it and more)
hopefully tomorrow i'll finish work early enough to replace strut tops, inserts and put in 30mm lowered springs.
VB: started removing old dash to complete wiring up the rb30 and shoehorn a vk calais dash.
fuzzy2308
Plastic datsun
unlocked it then popped the bonnet had a smoke
opened the bonnet went and had a cuppa and a smoke
popped the boot to retrieve a screw driver and ratchet then sat on the boot seal and drank some coffee and had a smoke
pulled off one side of a heater hose then made another cuppa and had a smoke and some cold pizza
went and got a flood light and plugged it in then went and got the news paper from the mailbox and proceeded to look through it at the pictures while haven a smoke
stuck my hand between the engine and the firewall and got my elbow stuck once i got my arm out i precoded to stair at the engine for about 15 minutes while haven a smoke
then i removed the opposite side of the heater hose that i removed earlier while i coughed up a lung or two
considered trying to work out how the #### im meant to remove the metal Y fitting on the coolant bypass then staired at the engine some more
had a smoke then closed the bonnet and went back to sleep
GothicKidd
ლ(ಠ益ಠლ
South Australia
VR S2 Exec
Drove it, thought wow this temperature gauge is working for once, going over a quarter and reaching half way! shocked..
I soon found out I needed coolant and topped it up.
mr calais 5.0
victoria
vy s 2003
Washed, tire shine and shammy her down, took some pics with the super lows on..
