- Apr 15, 2006
- 22,664
- 20,590
- 113
- Location
- Sth Auck, NZ
- HSV VS Senator, VX Calais II L67
You're comparing two peak figures though and are disregarding any torque gains under the cross over and any throttle response
The TP single had it's higher peak torque figure at a lower RPM than the peak torque of the DP manifold. Torque x rpm is HP so the SP manifold made more power at the lower torque peak than the DP manifold. That SP manifold coupled with the correct transmission and final drive ratio would have perfectly fine throttle response.
Like I said in my earlier post, the OP has not stated what driveline combo it has or intends to use and also hasn't really stated what the intended use is. Without this info recommending a manifold is a waste of time. His only advise was it had to fit under a HQ bonnet and that is a very limiting factor.
