what relays go where
mzrose
wollongong
vr executive 95
currently have no power to my air con fan wondering if I have the correct relays does anyone have a picture of the fuse box from under the bonnet in vr 1995 commodore please
krusing
Melbourne, Bayside
Did it not have relays installed ?,
If so, did you not take a photo of it before pulling them out ?
mzrose
wollongong
vr executive 95
it does all the same black 4 pin but fuel.pump has the silver, just wondering if they are all the 12v 30a or different as seen someone put a 5 pin in the lp/check and it made their air con fan work so thought maybe I jad the wrong relay?
woteva
NEED 4 SPEED
Adelaide S.A.
Are you talking about the air cond fan behind the front bumper ?
Or the fan under the dash for the air vents ?
If it is the dash fan located behind the glovebox, the most likley failure is the fan resistor located under the wiper plenum cowl.
mzrose
wollongong
vr executive 95
under the dash. is it an easy fix? I know im a chick but I'm quite cluey considering just done bit of work on my car atm
Fu Manchu
WA.
I’m pretty sure it was @BlackVXGTS that has the VS workshop manual. He might have a schematic to post. The manual needs a bit of work to get it to run because it’s such an old format.
grey_hawk
S.A
VR V6 Ute, VS V6 snotbox
These are out of the Gregory's...If you need I'll get a better photo under the bonnet but is series one, won't have ABS or airbags.
grey_hawk
S.A
I can confirm the LP check relay is 5 pin.
The blower relay is a 4 pin,the socket only has 4 supplied pins.
So you have the wrong relay fitted.
BlackVXGTS
Melbourne, SE
Just to clarify, does your heater/ac fan not work on every speed setting, even the highest setting?
You can test if the relay is working by swapping the blower relay with the horn relay.
