Where is the .....
DHB000
2010 VE International
Where is the switch/sensor for the interior lights on my car ???????
Ive looked on all the doors and cant find anything ...
I want to add footwell LEDs that turn on when the door is open but just cant find where the trigger is ????
Im starting to think that it is in the key electronics ???
Or do I have to add an extra switch somewheres ??
thx :idea3:
Muke
VE SV6 MY08
I believe it's part of the door catch mechanism.
Jimbov8
Mt isa
WM Statesman 6L
thx :idea3:
It's inbuilt with the door latch mechanism it also control's your radio to turn off when you open the door etc...
Zerone_V
Lexus IS350 (SL)
Your best bet is to connect to the BCM, which is located underneath the steering wheel column, drivers side, behind the dash (Up and behind the headlight switch).
If you connect here, then the fade function, interior lights On on unlocking, etc will work, and apart from it being a pain in the butt to get to the wiring,
once you have spliced in you can add the factory footwell lamps, factory door lamps, interior door lamp lights, and even puddle lamps if you are feeling saucy.
image.php
What you want to connect to is the BCM X2 Connector, Pin 5 for the Supply Voltage, and just use a ground from anywhere.
image.php
Pin 1 - Orange - Inadvertent Power Supply Voltage
Pin 2 - Orange / Blue - Battery Positive Voltage
Pin 3 - Grey - Instrument Panel Lamp Supply Voltage
Pin 4 - Not used
Pin 5 - Dark Blue / White - Courtesy Lamp Supply Voltage
Pin 6 - Not Used
Pin 7 - Not Used
Pin 8 - Brown / White - Park Lamp Switch On Signal
Pin 9 - Not Used
Pin 10 - Dark Blue - Rear Compartment Relay Switch
Pin 11 -Light Green / Black - DRL Ambient Light Sensor Signal\
Pin 12 - White - Headlamp Switch Headlamps On Signal
Pin 13 - Not Used
Pin 14 - Not Used
Pin 15 - Not Used
Pin 16 - Not Used
Pin 17 - Dark Green - Headlamp Switch Headlamps Off Signal
Pin 18 - Pink / Black - Courtesy Lamps Switch Signal
Pin 19 - Not Used
Pin 20 - Light Blue - Tow/Haul Switch Signal
Pin 21 - Brown / Orange - Traction Control Switch Signal
Pin 22 - Dark Green / White - A/T Shift Lock Control Solenoid Supply Voltage
Pin 23 - Not Used
Pin 24 - Not Used
Pin 25 - Purple - Interior Lamp Switch Signal
I hope this helps.
DHB000
Thx Zerone_V heaps
so just to get this clear in my non auto electrical head
OK so I find pin No5 on the BCM , or dark blue with white tracer wire under the dash and use that for a power supply for the new footwell lights ??( and they will work with the interior lights when they are on now ???) and of course an earth somewhere
And when that works I also want to add "Puddle lights" to the doors .
All the lights I want to fit will be L E D s
Big question can I add all of these extra lights to that power supply or will it overload that electrical system on the car ???
There is always a plan B ....
Do I just buy a torch ???
cheers
RiCeY
F O R U M W A R R I O R
Australia
VZ SV8 6spd 6.0 430rwhp
Shouldnt be an issue they dont draw enough current to cause problems.
