CANYONERO
Likes Cheese...
- Mar 29, 2006
- 1,028
- 12
- 38
- Location
- Country SA
- V8 6spd wif MOMO leavaa.
yes, if you got fans for airflow you wont have a worry.
Hi adam im having dramas with my system setup im no techy so i dont know audio but payed a bloke to install it all for me and nothing is working properly after he left, been goin on for about 2 weeks the guy hasnt been back hes suppose to be well respected and a professional but this job looks anything but, i have 2 6x9 in rear parcel shelf of my vp and a pioneer sub & amp in the back, he grounded it to paint work in the boot and only has the main power wire running off positive and down the passenger side of the car, tge 2 6x9s work but only until the headunit says its miswring, what am i to doJust another point dude.. you should run your power wiring down a different side to your speaker wiring. I did an amp and speaker install about a 2 months ago for my vy... took me ages to do it (hours and hours).. if you need any help with it pm me, i should be able to help you with any questions you have.
It would be best to rewire the install. Depending how he wired can be a issue for you. Eg: If the headunit is plugged into the factory harness the speakers could be still conected to the factory conecters and simply check - & +. The amp/sub should be rca leads from the headunit (aftermarket) or may have an alternative if factory. If the system is wired alternatively and not into the factory loom socket best to start again rather than faultfinding unless you are experienced in auto elec.Hi adam im having dramas with my system setup im no techy so i dont know audio but payed a bloke to install it all for me and nothing is working properly after he left, been goin on for about 2 weeks the guy hasnt been back hes suppose to be well respected and a professional but this job looks anything but, i have 2 6x9 in rear parcel shelf of my vp and a pioneer sub & amp in the back, he grounded it to paint work in the boot and only has the main power wire running off positive and down the passenger side of the car, tge 2 6x9s work but only until the headunit says its miswring, what am i to do
heat rises does it not?? so when an amp is upside down, all thet heat is trapped inside of it. it cant vent the heat out .
