- Apr 15, 2006
- 22,640
- 20,536
- 113
- Location
- Sth Auck, NZ
- HSV VS Senator, VX Calais II L67
Recently in a thread there was a lot of debate about the need to degree a cam shaft when doing a simple cam swap. Our esteemed LS expert said there was no need.
Well here is great proof that you should always degree your cam shaft. In this case we have a VCM cam, a reputable supplier of many a cam found in Commodores these days. When the cam was installed straight up it was found to be off. They ended up going +4° to get the intake valve lift at TDC correct as per the cam card provided (video time indexed at the start of the cam timing segment).
Degree your cam shafts people, and if it's been done at a shop ask if they will degree the cam!
edit: I'm not saying the problem with this cam install lies with the cam, as the engine builder explains in the video, there are many area's where the error could have occurred. The point is to check/verify and remedy.
Yea but if you're an engine shop these things don't take very long as they have guys that do different things.
It all depends on how much work is going to be done. For a street car with a cam a lot of the things you mentioned aren't worth dooing. Like degreeing a cam like who does that on a cam swap and tune for a street car?
