Will redline Rims clear Hsv Brakes
HotdogNo1
QLD
VF SSv Redline A6 W407
Hey guys I brought a set of VE E3 Hsv Brakes. Will my redline (VF 19''x8.5'') rims clear the Calipers
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
The Redline wheels should have the same offset as HSV wheels(fronts).
My VE Redline wheels clear Brembo's, AP's, and Harrop brakes.
mitchy_
37
QLD
Senator SV08
The same offset doesn't necessarily mean they clear big brakes, the spoke design does.
Redline wheels should clear HSV AP's though, as they are similar sized calipers.
HotdogNo1
QLD
Great thanks Guys for the info .
HotdogNo1
QLD
Installed my new pre-loved Hsv 4 pot Ap racing calipers & rotors (bolt straight up) on my SSv Series 2 today. The VF redline rims clear the big brakes no problems. Rotors (Hsv)Front 365mm Rear 350mm
I used new Hsv brake lines on the front with new copper washers all round and new Hsv caliper bolts about $6 each. Machined the disks and new Rda extreme brake pads.
Also for the rear brakes, you will need to cut the dust cover at the back of the old rotors to fit the new larger HSV rotors.
