Wipers dont spray water anymore
Sean4aus
30
Holden VE Commodore SV6
I had a crack in the windshield and Obrien came out to replace it but now water doesnt spray out of the wipers anymore.
The reservoir is full - i checked. I am wondering if maybe they disable/removed something to fit the windshield and forgot to connect it again?
Any ideas?
gossie
Gold Coast.
VE International 3.6L
Wipers don’t spray water on a VE.
Sean4aus
30
I have an '08 VE Commodore and it comes out of the wipers as they go over the windshield
tml678
2017 HSV30 Senator, 2002 Corolla..
Can you hear the pump motor activating if you open the bonnet and pull the wiper lever from outside the car (ignition on of course)?
Sean4aus
30
yeah I can - i think, the wipers make alot of noise so it could be that. Im not very car savvy
tml678
lift the wipers off the screen and listen for the motor/pump. It will be located directly under the reservoir. It's just one of those little ones that make a distinct buzzing noise. If it's working, you'll hear it when you pull the stalk. Don't start the engine, just turn key to 'on'.
Sean4aus
30
Okay, thanks for clearing that up - I cant hear anything.
Likely a pump/motor replacement?
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Maybe, have you checked the fuse?
Fu Manchu
WA.
It’s also a possibility they didn’t reconnect the hoses on the wiper arms.
Look for water dribbling on the ground under the car.
