Wiring
G€€.R$
34
Bankstown
RS v6
Does anyone know which one is positive and negative wiring that connect to the headlight bulb cause im putting LED and need to know which 1 is which
ephect
Donating Member
VS Acclaim V6
They should have the standard connector. Plug and play
If they don't work, send them back
stooge
wa
Turbo Alpaca
they will be a h7 plug and you just plug them in and if they dont work then turn the plug around, they are not going to explode if you plug them in the wrong way.
your next thread is probably going to be something about check dipped beam message on the dash.
Fu Manchu
WA.
The days of cutting looms to fit this stuff is 10 years in the past. Should be direct replacement bulbs now.
Immortality
Staff member
Sth Auck, NZ
There are direct plug and play LED head light bulbs but I don't think many are street legal. Ones I know off are H4, H7 and possibly H1
Fu Manchu
WA.
Technically, no bulb that is different to what the car was made with is legal. Even different Halogens. (From a technical perspective).
This is where the fight starts.
G€€.R$
34
Bankstown
RS v6
Thanks mate that's all I wanted to know and make sure they don't over loaf or short circuit something in the car ill give it a go and letcha know. Thanks buddy
