Wl statesman leaking water
Cooperse21
Wl statesman
My statesman is leaking water from above foot pedals drivers side any ideas what it is I’ve checked seal and cleaned out drain points but still floods in side my car
_R_J_K_
Zenki S14
Which seal did you check? At a guess the heater core has sprung a leak or one of the coolant hoses to the heater core is busted.
rambunctious
Alexandra Headland Qld
VZ Executive Wagon
Most cars have a tray in front of the windscreen to catch rain and divert it down a hose each side to under the car.
Have you looked into this ?
Windscreen may be leaking also.
Fu Manchu
WA.
The VZ drains straight into the wheel house/guard.
Fu Manchu
WA.
Remove the wiper cowl. Clean it all out and inspect it for things like missing or poorly applied seam sealer. It might be that if a gap was left in the seam, it might not have mattered, but as debris builds the water is leaking in.
Windscreen seal might have been compromised.
AC drain might be blocked. Get under the car and above the transmission is the little tube it drains from. Use a coat hanger wire or narrow plastic to carefully clear it. Squirt some water into it and flush it a little.
If the heater core has let go, you’ll have coolant in the cab, not water.
Remove the door trim, inspect the plastic weather/dust sheet is intact and sealed all around. Water comes through a perished weather strip on the door, down the inside of the door, onto the trim, down into the footwell.
slangenator
Donating Member
V2 CV8 Monaro, VY2 R8 Clubby
Sunroof by any chance? Blocked drains will do it. The other thing to take note of is if it only leaks after the a/c has been on - possibly a blocked heaterbox drain.
