WM Caprice reverse cam wiring
aerobr
gold coast
Jeep SRT8, WM Caprice, VE Wagon
Hey guys,
Having issue with reverse camera wiring for the WM...now here's the difference the wm reversing camera has completely different wiring colours to my Ve wagon. Does anyone have the pinouts for wm?
At the cam plug on a spare WM camera I have : light green, light blue, white, black, pink and red .
At the cam plug on the camera fitted to original WN mould I have fitted I have : 2x black, white, brown, yellow and a red. Any assistance would be great for this one lads!
Cheers in advance!
Todd
VT2Commie
WA
VT2 Clubsport R8
What are you trying to do, whats the end result you want?
And what year is your WM?
And is WN ???? a typo.
aerobr
gold coast
07 WM.
Have a WN mould fitted with camera, also a spare E3 WM camera. That's the wiring colours I have I listed above mate.
Hooking up reverse cam to the IQ conversion I've fitted just need to know the wiring colours pinouts for camera so I can tap into loom.
VT2Commie
WA
VT2 Clubsport R8
And what head unit have you converted to?
Genuine or aftermarket?
If you're going to use the WN Camera.....
RED - Ignition voltage/power.
WHITE - Reverse Signal.
SINGLE BLACK WIRE - Earth.
BROWN - SHIEDLED VIDEO WIRE.
YELLOW - Video signal +
BLACK - Video signal -
If you're going to use the HSV E3 Camera......
Confused,
What is the colour of the BARE BRAIDED video wire that is in with the PINK and BLUE wires?
Also there should be one wire that should be PINK with DARK BLUE trace.
Yeah?
aerobr
gold coast
Wm IQ with sat nav is what I've installed mate.
This pic is the small green plug from the WN camera showing what's there colourwise.
I just threw the wiring up for the E3 camera as it seemed strange it was so different mate.
aerobr
gold coast
This is the E3 camera that came on a grange bootlid I picked up to repair my spoiler.
See why I'm stumped? It doesn't match anything I've seen colourwise. I can remove the foam covering and look for shielded wire if needed....
VT2Commie
WA
VT2 Clubsport R8
Chuck the E3 camera and use the newer WN camera.
What vehicle did the Holden IQ system come out of, Year/Model?
aerobr
gold coast
WN camera is fitted to car now.
2012 model IQ mate from memory.
Cheers for the assist!
VT2Commie
WA
VT2 Clubsport R8
Got it sussed?
aerobr
gold coast
Not yet mate
Work and away from car ...sunday should get a look. I'm thrown by that brown wire in the plug?
