aerobr
- Apr 11, 2008
- 59
- 10
- 8
- Location
- gold coast
- Jeep SRT8, WM Caprice, VE Wagon
Hey guys, well Its time to reach out and see if anyone has a better idea than I on this issue, I'm getting tunnel vision and its become a pian in the ass! Much detail as I can in here hoping its something stupid..
Basics at the beginning: 07 WM with L98, dual fuel car, dropped lifter, mech damage, rebuilding that block for another car, bought a 2010 L76, known runner for transplant.
Swapped valley plate/oil pressure switch and intake manifold/TB setup for LPG from the L98 etc
For reference, all Original ECM/BCM/Key..
Motor was dropped in and everything put back together.....No cranking!
Next steps: had the laptop plugged in by tuner he stated antitheft was active, unknown reason, shut that off to get it cranking. Cranks, however no injector pulse, no spark, no fuel. Checked CAS, wiring had been pinched and stripped when they fitted starter motor back in, replaced CAS with known good one, and repaired wiring. Also found broken earth on rear passenger head, fixed that also. All fuses check out in bay and kick panel. 12v and ground at fuel pump relay but no ecm signal to prime or run.
Now the Safety Mode active/ Reduced power/ Stability ctrl error/ ABS error all display on cluster.
Basic obd reader logged P0122 and P0223, along with a body code which I didn't record something bizarre like BA222??? All cleared apart from the two TPS/PPS codes staying active. Wiring loom seems ok at TB and pedal is plugged in all looks good. But I didn't envision either of those stopping engine from starting at least??
At this point I'm open to suggestions and advice..we are scratching our heads..
I read an old post of Riceys? regarding voltages/grounds at ecm ill endeavour to run meter over that in next two days if I get chance before work, but after that I'm flying blind guys, any input appreciated!
Todd
Todd
