Skylarking
- Feb 3, 2018
- 10,165
- 10,695
- 113
- Age
- 123
- Location
- Downunder
- Commodore Motorsport Edition
Not sure what you mean... if the “quote” you mention is the repair estimate, then as you have an agreed market policy that lists your cars writeoff value as $7200, then it is a writeoff. Not sure why the assessor would be asking you what you want to do?UPDATE - assessor reviewed the quote (it came in at $7500) and then called me to ask what I wanted to do. He recommended write off as he said there was evidence that the timing chain was on the fritz and that would just cost me more money in the end. Thanks for all your helpful advice.
If the “quote” is their offer for payout, then you are on a market value policy which is confusing as you’ve said you are on an agreed value policy.
Also not sure why the assessor would be talking about cost to repair timing chains as such would be understandable if you were on a market value policy where they try all sorts of tricks to have you accept the notion that their payout figure is fair (but in your case it’s not relevant in an agreed value policy).
I‘d re-read your insurance policy to clearly work out what sort of policy you are on... I’d also ask the claims clerk the question “am I on a market value policy”.
The normal case is that a low mileage example is worth more than a higher milage example, sometimes much more.No idea. I haven’t gone back to see the car and I don’t drive it (hubby does). The assessor said it had relatively low kms for its age but didn’t say how much sorry.
Seems like you need the conditions of your policy clarifies because if you are on a market value policy you need to check whether you can actually buy your model with similar kms for the money they offer. if not you need to counter with the advertisements as proof their payout is deficient.
I know I’m labouring the point but when dealing with insurance claims, you really need to understand the terminology and the terms of your policy and fight for the best outcome, otherwise you will be shortchanged .
