spikeu
- Dec 5, 2005
- 14
- 0
- 0
- Age
- 54
- VX2
i own a vx2 commodore sed, its got a balance problem. i am not sure if it coming from the tyres, its fitted with Falken Ziex ZE-326 . the size of the tyres are 225/50/16, the o/e tyres on the car was brigestone 225/55/16. i have had the rebalanced each 3000k/m, as the car gets a bad shake about 90k/m
i find it starts as a driveline vibration an works through to the steering wheel
i have looked under the car many times, i notice holden had changed the tail shaft over the vt commodre. where on the vt it had a rear universal joint
the vx2 has a rubber flexible coupling.i am starting to think it a tail problem
as having this type of coupling, must put a big load on the centre bearing
as over the years i have replaced a lot of the on the old VB to VL. i have replaced all shocks with monroe reflex and rear coil with holden fe2 wagon
spring.i was told by one of there holden places, that the fe2 wagon springs
are heavier then the std sed springs.the o/e coils had EJ prod i.d code
the wagon coils are EL prod i.d code. it made the ride a bit firmer, but no change in the vibration. if anyone out there who had this problem with vx2
