KRUPTD
VN BT1 5L
- May 7, 2007
- 316
- 4
- 0
- Age
- 41
- Location
- Griffith, N.S.W
- VY SS Crewman,XE Falcon,HJ V8 panel van,HZ tonner
Hi,i have just fitted my active twinn throttle body setup onto my VN 5L.Its running but i need some help please.Well it revs at idle 1800rpm this is because of the second throttle body sucking in air due to the idle iac motor vent passage,because when i put my finger over the whole/vented to the iac motor in the throttle body intake side it idles at 800rpm no worries.So i was wondering if any one knows why this is happening???I thought if you have the iac disconnected the car would stall or would have trouble idling...Or how do you reckon i could pulg up this vaccum leak/fix it.
And the second this is i need some help with a throttle linkage for the 2 throttle bodies to open at the same time.I have both throttle bodies mounted with the accelerator linkages at tthe top of the hat,so was wondering if anyone had any good ideas to link them together to open at the same time and also at wide open throttle.I have attached some pics of my engine with the manifold on.
