Okay, got a new V6 Buick engine like 6 months ago and the it went fine for a good long while nothing went wrong with the actual engine
On thursday morning i degreased and sprayed the engine down (didn't drive)
Friday morning i had to leave newcastle to get to wollongong, so i left drove about 10kms and noticed the oil light on, pulled over turned out to be the filter wasn't on properly...
all good til i got to Bulli Pass, at the bottom it felt like she was losing power under load, not misfiring, pulled over and had a look, the pressure switch was pouring out oil, no warning light was on (???), so i got a new switch and some oil, all was good til the next morning and now it misfires under load
my question is what is a likely scenario that would cause each of those problems?
sparkies are fine, looks like there could have been oil splatters coming out the exhaust
Missfire under load can be the leads - if all is good on the flat but when it comes to a hili it starts to miss fire cough and fart - I'd say the leads are shot.
and 3 Dangerous non ABS VN's
I only just replaced the leads they're brand spankers... i know i have a problem with the spark in cylinder 1, checked it not long ago with a timing gun... but it wasn't this bad, it wasnt like it was missing or anything, just not sparking evenly
Still no idea whats happening, by the look of some posts on another site it could be a head gasket... anyone got some pointers, i've been meaning to do all the gaskets for a while and this seems like a really good time to get stuck into it
u sure u have the leads in the right order
Wrecking VL factory V8 only a few bits left still have full dash/crash pad
and have a vk 202 motor and 5 speed Make an offer want it gone
Could be just water shorting out the DFI or coils.
Remove the first two leads from the the first coil pack and start it. If the spark jumps from pin to pin then the coil is fine, if it goes down or anywhere else then the coil is stuffed. Repeat for all 3 coils and see how it goes.
(Taken from another thread, not my idea, but it worked for the mulligan-can)
i have oil bubbles in the coolant... but not milky.... pretty sure milky oil is the diagnosis for a really bad head gasket....
Leads are in the right order... lol!! i'm not that bad
i'll have a look at the Coils and EFI** pretty sure the Fuel injection is fine though... could be a gummed up injector.. hadn't thought of that til now
already have the intake manifold off and noticed the gasket has 2 major cracks on the back end... i'll dig a bit deeper but if i can't find anything i'll just replace that
I have a VY to drive around in until it's fixed... but it 's an auto XD
most likely inlet manifold gaskets more than anything the head gaskets are pretty bullet proof
Replaced the intake manifold gasket... was running beautifully for about 10 minutes, then the oil pressure switch came back on
apparently it could be wet.... i'll look in the morning... couldn't be bothered right now i've just spent all day on it to have it stuff up again...
not misfiring anymore XD one plus, and the old gasket fell apart in my hands lol no wonder it wasn't running well
oh and then the check engine light came on
guess what!!!
i couldn't take the idea that something was wrong so i went to the garage armed with a can of WD40 and my girlfriends hair dryier..... as soon as the hot air touched the il pressure switch... water started spyrting out of where the pins poke through... just got some paper towel and wiped it up... all fine now... why are the most annoying things so simple?
need that rubber ring that goes around the plug.... dunno how i lost it
