Results 1 to 11 of 11
Thread: TH700R4 V6 & V8 Differences
    VN Calais S2
    Sep 2009
    Melbourne West
    Default TH700R4 V6 & V8 Differences
    Thought I'd start a thread on the differences between V6 & V8 model trannies as V6 trannies are plentiful and fairly cheap to source, as opposed to the V8 tranny. Apart from the obvious bell-housing & input shaft difference's i'm asking anyone in the know if the internals are same ? ... for the many of us with tender V8 auto's and some bush-mechanic skills could we transplant any V6 components and keep our rides rolling that little bit longer? any knowledge welcome
    Morton's Avatar
    Fairstar the Funship
    May 2006
    I dare say it would be possible. I'm not aware of different part numbers for trans service kits or shift kits for either model. So the valve body must be very similar if not identical. I'm not sure if the V8s run stronger clutches, but I doubt it given how fast a 304 can destroy an old T700. I'm also fairly confident that the servo setup would be identical.
    As far as I know the gear ratios are the same too, so the only differences that I'm aware of are in the physical size of the shell and bellhousing, and the size of the torque converter.
    The 1972 HQ Kingswood
    VP Executive R-spec
    Jan 2005
    VN Calais S2
    Sep 2009
    Melbourne West
    thanks for your input guys so far it sounds promising
    I'll let this thread gather some info then i'll get the tools and camera out :P
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    i always thought the difference between the v6 + v8 gearbox's where the input shafts? maybe longer or different amount of splines something? (im just guessing)
    I could be wrong and most likely am, i remember seeing something about it ageeeeeeees ago so dont know how true it is
    VP Executive R-spec
    Jan 2005
    The shafts would be different lengths? but the insides should be the same
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    usualy the only differance is ratio not strength. (first/second) gear is taller.
    this applies to 2 speed power glide, is 1st gear is taller in V8 thats the only differance.
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    Quote Originally Posted by greenfoam View Post
    yeah pretty much what i was thinking but like i said, i could be wrong lol
    VN Calais S2
    Sep 2009
    Melbourne West
    Quote Originally Posted by padrickz88 View Post
    well for the price of a reco tranny I aim to find out lol
    VP Executive R-spec
    Jan 2005
    VN Calais S2
    Sep 2009
    Melbourne West
    thnx greenfoam. Definately the most difficult will be learning all the components and their function.. nonetheless I'll plod along and chew like crazy.
    I have the necessary donor V6 auto's (two in fact) and as I accumulate some knowledge will begin stripping one down. Anyone out there with a shagged V8 T700 willing to donate would be great. Otherwise i'll see what the wreckers have on offer.
LinkBacks (?)
  1. oil differences
    By butch123 in forum General
    Last Post: 03-08-2009, 09:53 PM
  2. vz sv8 and vz ss differences
    By jester419 in forum General
    Last Post: 23-05-2009, 10:21 PM
  3. VS BCM Low & Mid differences?
    By Shambo in forum Electrical Wiring / Questions
    Last Post: 24-01-2009, 04:40 PM
  4. V8 differences
    By bangers in forum General
    Last Post: 20-06-2006, 02:12 PM
  5. vs/vr differences
    By sarj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-08-2005, 12:32 AM
