Results 1 to 10 of 10
Thread: Heater to cold
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    Default Heater to cold
    i have a new heater valve and have flushed the heater system for blockages 2 times in the last year (the second time it did nothing) and yet my heater still dosent get hot (only mild warm lucky if its over 25c) why is this?
    are vn heaters just bad. when i touch the copper pipe at the drivers side feet i will get burned if i hold it there and when i switch the hot to cold dial i hear it moving the trap doors.
    YMY-88U's Avatar
    YMY-88U is offline Donating Member
    Project VH SL/E
    Jun 2005
    well i dont know about anyone elses, but my heater is damn hot!! i only just recently replaced all heater hoses cos they were clogged of crap and now it works like new.
    same with my air con, although i havent changed anything on that its bloody cold. maybe your not getting any water into the hoses.
    cos at the time when i replaced the heater hoses, i replaced both inlet manifold gaskets and both head gaskets and gave the head a good flush through.
    but thats just my 2 cents
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Yeah, the heater in my VN is incredible. Puts me to sleep in no time LOL.
    Is it possible that your heater core is blocked and won't allow much water to flow through it?
    Gravity is proof that nature keeps getting us down.
    VR SS manual
    Apr 2006
    id say maybe the door inside your heater box isnt working even tho u can here it as the water is entering into the car
    VP Exec,honda civic,mazda626
    Jan 2006
    watsonia
    id agree with mouce change the heater core mine wasnt to hot in the vp since i changed due to a leak hot as hell now
    mouce's Avatar
    Jul 2005
    The only problem is that doing a heater core in a VN is not a simple thing. According to the manual the dash has to come out, and you have to disconnect part of the aircon as well...
    To me this sounds fairly expensive.
    Jan 2006
    watsonia
    nah just take the front radio surround and just cut the old one out then cut the new one the same bit shorter and join it with heater hose and some clamps i did this for a total price of 30$ i got a good one from the wreckers same was done to that and it was virtually brand new
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    so my heater core maybe only half opening or something since yours all work good.
    thanks
    foammedia Guest
    lay on the floor near the pedals and study that white plastic level the heater dial opens, investigate that
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    Quote Originally Posted by foammedia
    i have investigated the dial :P all in working order (i found that lever when the rod from the dial used to keep falling off)thanks for adivce tho. me thinks the core bit is screwed will find out how to change it at then cahnge it when i get time
  1. heater
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-04-2007, 12:22 AM
  2. climate control blowing cold aircon on cold days
    By stackner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2006, 03:24 PM
  3. A/C with heater ??
    By davey g-force in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-07-2006, 09:32 PM
  4. Cold Heater all the time. Any Ideas ?
    By Madhouse_Dave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-06-2005, 06:09 PM
  5. Heater
    By gospeedracer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-11-2004, 04:00 PM
