Results 1 to 15 of 15
Thread: What needs to be done to put VT twin pistons on a VS??
    vs acclaim
    Apr 2009
    Melbourne City
    Default What needs to be done to put VT twin pistons on a VS??
    Help please?!
    what needs to be done to put VT twin pistons on the fornt of my VS?
    becasue ive herd that you need to buy an adaptor of some sort, or somethign along those lines?
    so if some could please help and advise me what needs to be odne would be greatly appriacted.
    Thankss.
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    you need to do the " VT brake upgrade " which includes larger discs. Search for that and you will find loads of info.
    VS S-Pack SII
    May 2008
    Ok... from what i understand...
    FYI: The VS hubs are the same stud pattern, but hub size is smaller than the VT one.
    Step 1.
    You need at least 17" rims (maybe 16"??) or the calipers won't fit inside the rim.
    Step 2.
    - You can buy stock VT brake disks and user spacer shims on your VS hubs to bring them up to the VT hub size. (Which is a bit Dodgey)
    - Or special "upgrade disks" that mount onto VS Hubs.
    (Code: DBA040BSL for Front Left & DBA040BSR for Front Right)
    - I have also heard of swapping over the whole VS Hubs to VT ones. so the Stock VT disks fit. (DBA040SR and DBA040SL) but im not sure of this????
    Step 3.
    The VT calipers will swap directly with the VS ones. but you will need different flex hoses that go to the callipers, as the VT inlets to the callipers are in a different position.
    Step 4.
    after reconnecting all the lines, bleed the system.
    Note: This will surfice, but... your pedal feel will suffer, as the pistons in the callipers now require more fluid, and hence, your pedal will push further to the floor, feeling more "soft" or "spongey" ...
    To Rectify:
    Step 5.
    - Upgrade your brake master cylinder to a 1" or a stock VT one. This will reduce the travel in your pedal. (I think you have to change the booster as well?)
    - This step will require you to make a new bracket or drill a new bolt hole on the master cylinder arm (or something?) so it mates up with your VS pedal box. a simple mod you can do yourself...
    Step 6.
    Big Note:
    *** Modifying brakes may require an engineers certificate to maintain a RWC. As well as for insurance purposes, please consult a qualified engineer before performing any modifications to your brakes. ***
    Jun 2005
    since he has a VS, the VT master cylinder will bolt straight up. no need for a VT booster unless he really wants it. VS might need brake lines bent a bit. apart from that, its an easy upgrade.
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    *note no 1 inch master available for the vs they are different to the vn/r booster master setups. They are 7/8. So if you are unhappy with the pedal you can do some small mods(i think) to fit the vt master to the vs booster or you can do a whole booster master swap to the vt one, which i can reccomend.
    But basically all as above
    Reaper
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    heres the how-to: How To - VT Brake Upgrade
    would you believe it? it was in the how-to section and the disc's used in that how-to are the modified vt sized discs with the vs hub, so no shims.
    vsiicalais's Avatar
    vsiicalais is offline Donating Member
    VEII Thunder SV6
    Aug 2007
    Warragul
    Also i would like to add, you can still run 15 inch rims, I have been running stock interceptors and vs berlina alloys without an issue. VT's also came out with 15 inch rims so no need to upgrade to 16 or 17's
    How To - Fix Reverse Lights For Free!
    http://forums.justcommodores.com.au/...commodore.html
    VS Executive
    May 2009
    I was looking for the same information , so i signed up.
    Start to finish tutorial: How To - VT Brake Upgrade thanks alot vsiicalais
    And alittle food for thought: Press Releases
    VE Spec Brake Upgrade from VB to VT
    vs ute
    Sep 2008
    i found on ebay some people are selling the vt booster and bmc for like $650 but then there is some guys selling them for $75 why such a big price difference?
    what are the mods you need to do to fit the vt boost and bmc to a vr ute
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Id say the 75 dollar special is sold as it was taken off the car but the 650 is probably new and has been modified to suit a older commodore as in this site if you look under mods Project VN AERO but you dont need hose adapters .
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    VS S2 3.8ltr exec A/T
    Apr 2010
    VS - VT Master Cylinder Conversion
    Could some one please clarify for me with 100% certainty (ive been reading threads for hours)
    Dose the VT Master Cylinder bolt strait on to the VS booster? or does the push rod have to be modified?
    Does the VS brake line require brass adapters for the M.C.?
    Do I put the VS resivior back on to the VT MC to keep fluid level? (should I purchase a seal kit before attempting)
    Any help would be appreciated.
    Has anyone made a "Step by step" and or "parts list" for the Master cylinder conversion specifically for VS - VT??
    (is anyone prepared to??)
    VS S Pack
    Sep 2009
    VT master cylinder will bolt straight up to a VS booster, no pipe adaptors needed, you can either use the VS one or leave the VT one on(I have not bothered to put the VS one on mine)
    wraith's Avatar
    wraith is online now Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    VT brake swap is old and outdated. VE swap is a lot less complicated and easier by far.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Quote Originally Posted by Trikky View Post
    NO it wont.
    The pushrod on the VS booster is longer than VT so the master needs to spaced away from the booster or the piston will be compressed. Do not pull out the booster pushrod as you risk the reaction disc falling off.
    The VS is booster is not powerful enough to cope with the increase in bore size of the VT master.
    The VS reservoir will fit the VT master but the hole in the metal tab needs drilling and tapping in a different position.
    Go VE and save all the stuffing around. You will get a better pedal feel and increased stopping power.
    Props for not starting yet another VS to VT brake conversion thread!
  15. #15
    Nov 2003
    northside brisbane
    Quote Originally Posted by Psmithavsupplies View Post
    List
    pre vs booster bracket cut and bent on ends and piece of flat 2 mm steel welded to it to suit the bolt pattern and centre hole of vt booster fitted to;
    Vt booster with hole in pushrod hole welded up and redrilled nearly a full hole forward to get the right pedal height
    vt cylinder with vs reservoir bolted to it...seal kit not really needed.
  1. Pistons
    By H1GHROLLR in forum LSx Development and Modification
    Last Post: 17-03-2009, 08:09 PM
  2. vr pistons
    By Adamvr93 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-09-2008, 11:36 PM
  3. Davies Craig Twin Thermo Fans and VS S/C Pistons
    By STL.THY in forum Parts And Other Items For Sale
    Last Post: 23-04-2007, 01:49 AM
  4. VT twin fan versus AU twin fans question
    By FXST01 in forum Electrical Wiring / Questions
    Last Post: 25-10-2006, 12:12 AM
  5. What pistons
    By chevy_big_block_bro in forum V6 Development And Modification
    Last Post: 08-11-2005, 06:11 PM
