hi car stopped one morning wont start turns over wont fire.
changed the coil it started,left it running running 4 ten mins.turned it off then went to start it again wont start just winds over.so i changed the coil and the ignition module it started let it run 4 ten mins.
turned it off and then tryed to start it again wont start just winds over.
has anyone got any ideals?
id be leaning towards the hall effect sensor in the dizzy... youve pretty much eliminated most the things, if its not the dizzy then it has to be the ECU cos theres nothing else that controls fuel or spark
Agree...sounds like it could be the HES. When mine went it would turn over but not fire...no injector pulse..
had problems with mine starting twice both time went threw every thing you could think off and both times was the dizzy
