Results 1 to 5 of 5
Thread: delco ecu differences
    vr
    Jun 2009
    Default delco ecu differences
    does anyone know what was changed in the various vr v6 ecu's? I have a few ecu's eg bmza, blcb & bk?? Cant see the other letters on the bk ecu. The bmza seems to have different shift points and tcc doesnt engage untill aprrox 105km/h. It also seems alot crisper in accel than the other two.. Blcb & bk?? Run fine but just arent up to the bmza. And no the bmza ecu is standard not chipped as i have 2 of them and they both perform th same. So can anyone confirm what parameters where changed throughout the vr model run.. Cheers ash
    Quote Originally Posted by v6monstar View Post
    dude your piston slapping your going to have to titan up your pistons be for you throw a con rod throw the side of the of your engine
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    BMZA1754 $11 94, 3.8L Auto 16176424 New Transmission Cal from robs site Rob's Creative Calibrations - Memcal Listings its for the new later trans that has an extra solinoid for TCC lockup
    vr
    Jun 2009
    thanks delco, so using that ecu in an early vr, the tcc wont lock up? Would using it cause any damage?
    VP Exec
    Jun 2005
    See what Delcowizzid comes back with but I think that the extra solenoid is a bleed to soften the apply rate of the TCC. Previously, it was either on or off only i.e. it might still work but it may throw a code.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    ide probably stick with the correct tune for the trans
  1. Tuning a standard v6 delco
    By frdhtr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-10-2010, 07:30 PM
  2. delco remy
    By Bunjey in forum Electrical Wiring / Questions
    Last Post: 14-03-2007, 08:05 PM
  3. delco or bosch?
    By Farlig in forum V6 Development And Modification
    Last Post: 26-02-2007, 07:14 PM
  4. Remanufactured Delco 808...
    By g00gz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-03-2006, 01:27 AM
  5. Delco Query
    By milz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-01-2004, 11:26 PM
