Results 1 to 2 of 2
Thread: Removing Cam from a VS V6
    VS V6 Manual Wagon / VS V6 Manual Supercharged
    Oct 2010
    Default Removing Cam from a VS V6
    Well ive never done this before, tried to look for a guide but couldnt find one. If anyone has and help or tips that would be great. Ive removed front end and radiator and such, looks to be enough room but does anyone know if the engine will need to be lifted at all?
    vs commodore
    Oct 2009
    Tamworth NSW
    (1) Remove the inlet manifold,remove the plenum chamber,remove the rocker arms and pushrods
    (make sure you keep the rockers ,their bolts and pushrods in the order of which cylinder they came from.).
    Remove the valve lifters,remove the timing cover from the front of the engine,remove the timing chain.
    (2) Remove the balance shaft gear and key from the camshaft.
    (3)Using a T30 torx socket,remove the thrust washer screws and withdraw the camshaft thrust washer.
    (4)Carefully withdraw the camshaft from the engine ensuring that the camshaft lobes do not damage the camshaft bearings as the camshaft is removed.
    To refit-
    Remove all traces of sealant from the threads of the camshaft thrust washer retaining screws and the cylinder block.
    Lubricate the camshaft bearing journals with clean engine oil and the camshaft lobes with lubrizol 6612 lubricant.
    Carefully install the camshaft into the engine ,ensuring that the lobes do not scrape across and damage the the camshaft bearings.
    Ensure that the camshaft rotates freely.
    Apply clean engine oil to the camshaft and thrust washer contact surfaces and install the thrust washer.
    Apply permatex lock nut or equivalant sealant to the thrust washer retaining screws and tighten to the specified torque.
    Install the key and balance shaft gear to the camshaft,ensuring that the marks on the balance shaft gears are aligned.
    Install the remaining components.
    Thats preety much it.You really should consider getting a gregorys workshop manual for doing jobs like this.These manuals have all the various nut and bolt tensions listed, and gives the removal and fitting instructions in detailed step by step form,you cant go wrong,and you know the job is all done correctly. Well worth the $50.Try not to get the haynes or max ellery manuals,the gregorys is much better,or even better again,a genuine factory manual,but they cost heaps more.Hope this helps.Cheers.
LinkBacks (?)
  1. removing cat
    By pillzor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-06-2009, 11:59 AM
  2. help on removing a/c when removing engine
    By sebstenator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-02-2008, 02:19 PM
  3. Removing Cat on V6
    By 5LUTV6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2007, 07:15 PM
  4. Removing Air Box
    By Swift Jimmy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-05-2006, 08:55 PM
  5. Removing H/U from VN
    By VN_WA in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2005, 03:09 PM
