Results 1 to 3 of 3
Thread: Immobilizer Problems?
    Projectile is offline imports (n)
    VS SS BT1
    Feb 2010
    Default Immobilizer Problems?
    Okay so whats happening is pretty much this,
    Every morning my car will start fine, every first start it starts fine.
    Drive around for 15mins or more and turn the car off,
    car won't start again for 15mins, nothing happens with the key, all elecs work with key on, no ticking noise, no noise whatsoever, remove the key, lock car, unlock car, try again, nothing....wait 15mins...starts...
    the white part of my ignition barrel (the part which is pushed inwards normally when key is turned) is permanently in but Ive never had this problem until recently...and now i does it every time i drive it...grr anyone got any ideas on how to fix this?
    i'm almost certain it is the barrel or immobilizer playing up...what do you guys think?
    any help greatly appriciated...
    vs commodore
    Oct 2009
    Tamworth NSW
    Check for error codes---Checking error codes VR/VS (Revised)---
    You will probably get code 31 which is to do with the ECU,BCM and the immobiliser system.Theres a 1 second delay in starter motor operation when the ignition key is turned to the start position when this code is active.You can clear these error codes by removing the negative battery terminal for 5 minutes.Also try moving the gear selector back and forth a bit, or even better,moving it to neutral instead of starting it in park when it does this,it could be a faulty inhibitor switch on the transmission.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Part of the problem may be that your ignition barrel is starting to disintegrate internally - this is not all that uncommon and then then just lock solid. If so, you'd be wise to replace it now otherwise when it fail you may be left stranded on the side of the road with a frozen barrel.
LinkBacks (?)
  1. Has anyone had starting/immobilizer problems
    By crewiess in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-09-2011, 11:07 PM
  2. Immobilizer problems....
    By pipzryd in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-09-2010, 08:02 AM
  3. where to mount immobilizer on vh?
    By budgieVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-11-2009, 07:28 PM
  4. Help Please:bypassing Immobilizer
    By janhdt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-05-2008, 10:12 AM
  5. Vp Immobilizer
    By Mad Dog in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-03-2004, 07:36 AM
