Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: Transmission Probs F#$K plz help
    VR commodore acclaim V6
    Oct 2010
    campbelltown
    Thumbs up Transmission Probs F#$K plz help
    Hey fellors, ok just today my car will over rev and strugle so hard to change gear sometimes it ends up changing others it wont at all happens after i hit 60 and after 80 ks after 60 ks which think is 3rd it rev but comes through but after 80 ks it jus rev rev rev wat the ### is it major? just need a trans service, plz dnt let it be a near transsmision if it is round how much is it, its ruined my day and pissed me off :@ thanks
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    Oct 2010
    campbelltown
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    do an auto service
    its a filter a gasket and new fluid
    if the trans is worn out (im thinking bands; like a manual clutch wears out)
    its a new box or recon the box...$$$$$
    Oct 2010
    campbelltown
    Yehh i was thinking bands need tighting but heaps people are getting these probs and having to get new ones man my luk is shit
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    before you condemn it!~
    i wpersonally would do an auto fluid and filter change
    may get you another couple of months out of it if there JUST STARTING to die (bands i mean)
    im not an auto expert but i dont think the bands in these autos are adjustable? no?
    *uwishn* is offline Holden special vehicles
    vl walkinshaw(replica) vt clubsport r8
    Jul 2010
    sydney
    i'm having the same trouble in my clubby my box needs a rebuild.
    My VL Walkinshaw replica project
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    oil change first people..
    also this eliminates low oil causing slippage of internal parts.....
    old filthy or contaminated or low oil in the trans can cause it to slip resembling a worn band or clutch packs...
    fluid in holden autos should be red on the dipstick and not smell burnt it is dextron3 OR ve etc dextron 6
    the oil is bright red aswell and has a sweet oil smell...
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    Does indeed sound like the usual worn out transmission.
    As said above perform a transmission service (Drop transmission pan, replace filter, refill fluid). Check the condition of the oil currently in the transmission, if the oil smells 'burnt' and is dark brown this is usually a sign of worn/burnt clutches but a service may help keep it alive longer. If the service makes a noticable improvement would strongly recommend fitting a trans cooler as the lower operating temperature will certainly help keep the trans alive longer. A service and cooler is definitely cheaper than a rebuild. Keep in mind that high RPM shifting into 2nd and 3rd will put a lot of strain on a worn band or worn clutch packs.
    Most likely culprit is a worn 2-4 band or burnt 3-4 clutch plates. 3-4 Clutch plates are prone to failure in these transmissions and can be replaced with a 'powerpack' to increase durability (part of a rebuild). The 2-4 band can be adjusted with the use of shims on the band apply pin in the band apply servo assembly but would only recommend doing this if you were confident in modifying your transmission. The seals and o-rings in the servo assembly will also need to be replaced if doing this as the whole assembly will need to be removed from the transmission to install shims. This will need to be done while the pan is removed from the transmission so the band is visible to check clearance. The installation of shims is also a part of the installation of a corvette servo which comes with the necessary seals and o-rings for the assembly. Installing a corvette servo isn't recommended in a worn transmission though as it will increase apply pressure which will exacerbate any problems with worn components.
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
    Oct 2010
    campbelltown
    thank you all fellors realy realy helpful im not real mechanically minded so cant do it my self
    i hope it aint bad cause i dnt have over 1000 dollars to get a new box im geting it checked out
    tomorrow morning and ill find out the verdict then to me i think its the worst case senario, i can still drive the thing just dont wana push it past 80 90 mark as thatl prob ### it up, great start to the yr aye boy? haha fml and i just got back from hollidays so SH$T
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    recomend wreckers transmission and do an auto filter service on the wreckers trans
    just make sure it less kms than yours
    a wreckers trans for these in brisbane can be as little as 200 bucks + fitment +oil and filter service
    food for thought maybe?
    Oct 2010
    campbelltown
    200!! for a transsmision wow would it bee any good tho? yehh man i jus hope i dnt need one but if i do il go wreckers thanks man
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    last one i got was out of a 180,000km vs (on odometer) into a vs with 260,000km's has been good for twelve months now
    it cost about 400 all up including oils filters and a carton of beer
    Oct 2010
    campbelltown
    Far thats heaps good man, im geting a recon -.- but i get 3 yrs warrenty on it so pretty good
  15. #15
    zelby11 is offline Banned
    SCOOTER
    Jan 2011
    NOWHERE
    Oct 2010
    campbelltown
  17. #17
    VSV6
    Jan 2011
    Koonawarra, NSW
    Couple of days ago my VS was doing the same thing, over revving, not slipping into gear. We were on our way to Sydney airport, 9kms away, others cars starting honking at us. We were at traffic lights, as we started to move smoke pissed out everywhere. We pulled over, opened the bonnet and flames over the inside of the bonnet. Hubby pulled his jumper off to put out the flames and we tried to see what had happened. Way too dark so we managed to drive her to a servo a about 50 metres up the road. She wouldn't go above 20kms and now has no reverse either, just revs but nothing. Had it towed back here to Wollongong and now trying to work out how much damage done. Guessing new transmission needed. The dipstick pops out everytime you try to change gears as well. There is burning around the leads and also on the engine block just below the oil fill. Any ideas on places to get decent priced recon gearbox in our area and other things we should check. Going to need to replace several wires as they melted in the fire, including the wiper tubing. Thanks. Luci.
  18. #18
    Oct 2010
    campbelltown
    Hey everyone got mi VR back today drives lyk a brand newie 1400 later but i get 2 yrs warenty and its so smooth.
  19. #19
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by DaveandLuciK View Post
    Sound like you need to replace your transmission
  20. #20
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    how did it do ?
    Quote Originally Posted by Paintabruh View Post
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
  21. #21
    96 VS SII 5.0 Calais
    Apr 2009
    Melburn
    sounds all too familiar. mine was slipping for about 12 months then last week it just cooked it and ive lost 3rd and it slips in every other gear worse than ever.
    ive bought a rebuilt transmission with a stage 2 in it.
  22. #22
    Oct 2010
    campbelltown
    Hey just bad yeh mate goes so good msn Duma great job need to fix centre bearing no may as well do my unis aswell
  23. #23
    Oct 2010
    campbelltown
  24. #24
    Sep 2005
    WHAT THAT cost you? if you dont mind me asking? without install costs
    Quote Originally Posted by brinz96VS View Post
  25. #25
    Oct 2010
    campbelltown
    sorry for dogy typing was on my ipod last night, what did what cost me my transsmision?
LinkBacks (?)
  1. radiator differences 2 transmission lines or 4 transmission lines...
    By Darkk_Calais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-01-2010, 12:10 PM
  2. Replies: 0
    Last Post: 17-11-2008, 01:51 PM
  3. auto transmission probs
    By SWE11L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2007, 10:09 PM
  4. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
  5. Transmission Probs
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-02-2006, 01:28 PM
