Page 1 of 5 12345 LastLast
Results 1 to 25 of 114
Thread: how to divert power steering fluid
    vs v6 commodore&vs v6 91 hilux 4x4
    Nov 2010
    brisbane
    Default how to divert power steering fluid
    I have put a vs ecotech into my 4wd and havent got the power steering box for my hilux yet .
    How to run the car without power steering hoses running to the power steering box . Can i just create a loop between the 2 hoses or block them off without damaging the pump .
    Hangman's Avatar
    Hangman is online now Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    I wouldn't block them off if the pump is going. You should be able to loop it, but don't quote me.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    Nov 2010
    brisbane
    if i block it of it would be the same as not turning the wheel wouldnt it
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Don't block it, you will have to loop it. The fittings/hoses are different sizes so it won't be easy. Might be able to cut the ends off a couple of old hoses and put a joiner/adapter in the middle.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    or get a short belt and a ribbed ecotec idler pulley for the tensioner
    Hangman's Avatar
    Jan 2010
    Quote Originally Posted by 91luxy View Post
    No, the pump is still going while the engine is running.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Wouldnt blocking it of just leave the pump idling? Like no issue there, just the same if it were running in a commodore and not turning the wheel.
    Reaper
    vr v6
    Aug 2009
    I dont think you should loop it because you'll be running a high pressure hose into a low pressure reservior. Also blocking the high pressure hose might wreck the pump.You can use a ecotec ilder pulley on a pre ecotec motor to get rid of the pump http://www.osp.metrohosting.info/v6ps.html but i am not sure about the ecotec.
    Nov 2010
    brisbane
    ha thanks Guzzoline addict and everyone.
    i ended up getting the hose fixed for the power steering so its now ready 2 start
    but its not starting. fuel pump is working(good fuel pressure, every thing is hooked up, turning over fine, no leaks
    how do i check the spark and injectors for power or something that is stoping her going the car is a v6 ecotec auto conversion in hilux 4x4
    в∞ѕтεכ √&
    Jul 2008
    NZ
    do you have a tune with no security or a bcm simulator if not it wont start
    Nov 2010
    brisbane
    в∞ѕтεכ √&
    Jul 2008
    NZ
    do you have constant power to A8 B8 at the ecu and switched 12 volts to A4 and E9 and an ignition power feed to the efi relay to turn on the dfi and injectors
    Nov 2010
    brisbane
    yes i think so should i go down and check that i have a volt meter but dont know how to use it realy
    в∞ѕтεכ √&
    Jul 2008
    NZ
    set on 20 volts setting hook one probe to earth on the body somewhere and use the other probe in the wiring plugs for the ecu
  15. #15
    Nov 2010
    brisbane
  16. #16
    Nov 2010
    brisbane
  17. #17
    в∞ѕтεכ √&
    Jul 2008
    NZ
    E9 and A4 should be pink just join them together
  18. #18
    Nov 2010
    brisbane
  19. #19
    в∞ѕтεכ √&
    Jul 2008
    NZ
    after that check power on the injector plugs with ignition on in the same way you just tested the ecu plugs and the red wire at the dfi plug
  20. #20
    Nov 2010
    brisbane
  21. #21
    в∞ѕтεכ √&
    Jul 2008
    NZ
    nope dont think so. maybe pull the E9 out the plug or cut it before bridging it to the other pink maybe its shorted out to something in the loom.have you heard the fuel pump prime yet while youve been messing round
  22. #22
    Nov 2010
    brisbane
  23. #23
    в∞ѕтεכ √&
    Jul 2008
    NZ
    depends how you wired the FP relay as well i think the fuel pump is the only + trigger output of the whole system
  24. #24
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you got a check engine light wired up yet it should light up with ignition on if ecu is powering up
  25. #25
    Nov 2010
    brisbane
    no but i have the wire identifyed if there is a way i have one of the smale liights from the headlight
  1. trans fluid and power steering fluid
    By jabba13 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2011, 09:51 PM
  2. power steering fluid?
    By mattgreen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-11-2010, 10:08 AM
  3. Vs power steering fluid q?
    By kritter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2010, 05:15 PM
  4. power steering fluid
    By -ToM- in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2009, 09:03 PM
  5. Power Steering Fluid?
    By Cody in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2005, 03:58 PM
