Petrol issues.... no power
futronix
44
2012 VE SV6 MY12.5
ok peps.......
just had the following done in the last month:
1. New fuel filter
2. New fuel pump
3. major service....
4. gas converter overhauled.... (leaking coolant)
and some other parts replaced.....
Now just this morning the car was running terrible on Petrol...... took a while to start and then had little power,,, cutting in and out!!!!
Since ive changed the fuel pump and filter and am getting suffecient fuel pressure... it this a fuel regulator problem???? How much is a regulator??
how do you get the fuel line off the regulator????
I have the car booked in where it was fixed to get the prob diagnosed but
thats not until next week so any suggestions would be appreciated....
cheers
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
Get them to check for a restricted catalytic convertor which can cause similar problems.
futronix
44
2012 VE SV6 MY12.5
thnx for your reply..... really doubt it is the cat converter....
BTW the problem doesnt happen on gas...... leaving the problem down to a fuel issue.....
im hoping its just a vacumn issue to the regulator as they messed wit that also....
dlzn
40
VS Exec SII 3.8 V6
yeah ive heard the stock cats are pretty bad and get blocked..
interested to see what the problem is :S
futronix
44
2012 VE SV6 MY12.5
will post the diagnosis on tuesday.......
futronix
44
2012 VE SV6 MY12.5
well its seems the DFI module is gone!!!! quoted $425.00 for a genuine module including the coils......
will get one and fit it myself.....
fitzy2005
Wide Bay, Queensland
VY S2 Berlina
:| wtf!!
how does it only affect petrol :S
i dont really no any thing about gas, so please explain
futronix
44
2012 VE SV6 MY12.5
yeah didnt really get it myself as on gas she runs fine....if any cares to enlighten go ahead!!!
ill be changing the module over with my friends VS statesman which also runs on gas to see whether in fact it is the DFI or not, before i fork out the $$ to buy a new one....
futronix
44
2012 VE SV6 MY12.5
well.... mechanic reckons it was the DFI Module 99% ........ changed over the whole DFI module with the coil packs from my mates VS and it did the same ****!!!!! WTF!!!
Going to test the fuel reg. today n hopefully it is just that!!!!!
HDT_aero
Banned
SA
manual VN aero
to test if the regulator is stuffed just clamp the fuel return line and start it up that will provide excess pressure but the comp will be able to compensate
