Give Castrol a phone call and ask them if the oil you have is suitable for your model. Holden V6 and V8 do not have "transaxles" so don't understand why the instruction say it is suitable ---CHECK FIRST. Dexron111 and gearoil are two completely different oils and do not mix plus if you put the wrong one in your gearbox you will probably cause damage.greatone said:i have castrol transmission and transaxle fluid it says its for holden v6 and v8 transmissions
