Hey all, my boot struts are out of gas (or something..) whenever you open the boot it tends to fall back down. I have a new set so I was just wondering how do I change em over?
Cheers!
PS: I did a search and found nothing. >.<
Just get a screwdriver and prise the clip that holds it on and it will come off.
MY RIDE
get a small flat head screwdriver, and get it under the little circular metal clip thing on each end. there should be a small slot in the strut where you get it in. once the clip is off, just pull it off the ball. not too hard.
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
Sweet, sounds easy as. Something for me to do in the morning when i wake up.![]()
just to be safe. make sure you put a stick under the boot lid to hold it up while you change the struts on by one....pretty damn heavy with out those 2 struts
Dammit, When doing this the struts in the boot are way smaller than the ones I have now... I think the ones I have are for the bonnet not the boot. =/ Unless I can make them smaller some how?
Nah the boot is fully open, but seriously, the ones that are in my boot right now are three quaters size of my new ones.
I tried making the new ones smaller but they're too stiff...
When I replaced them, the only way I could get them on was to lay on my back in the boot then by pushing up the lid with my feet to open it as far as I could, and with all the pressure I could manage to compress the strut, I was only just able to get the end the strut over nipple. You need someone around in case the boot closes on you, or leave the hatch down on the back seat, IF you can fit through. I was absolutely knackered when I finished. The amount of force you need to compress a new strut is incredible.
Just a reminder to all that when you do take these rubber stoppers out you replace them afterward. When I got my VR the struts were already broken and the rubbers missing. I didn't even know they were meant to there. When I went and bought new struts and installed them, they too were broken within a week. After comparing with another VR I realised that the boot was opening too far and breaking the socket that the little ball sits in.
and yeah the boots are quite heavy without them... they hurt!
