vt engine light came on
98vtberinla
40
gold coast
vt berlina
hi i have a 98 vt berlina series 1 filled up at the servo turned the car on and the engine light came on pretty much straight away while the engine light was on it reved slightly higher than usual(doing 100 on highway usally sits on 1500 when light was on did 2000)and also it was sluggish between gear changes ,pulled up turned the car off then turned it back on and the light hasnt come on since and has run perfect any ideas on what it could be???
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
Whenever the engine light comes on a fault code is usually logged in the computer. You can get the codes checked at Holden or any other place that has the right equipment. You can also check the codes on a V6 yourself, here is a link that will show you how: https://forums.justcommodores.com.au/threads/checking-error-codes-vt-vx.23665. This will not work on a 5.7 V8.
The fact that your car was revving at 2000 rpm instead of 1500 suggests to me that it was not changing from 3rd to 4th gear.
98vtberinla
40
gold coast
vt berlina
ok just checked it codes came up 12 and 19 why would i get 12(system pass)as awell as 19(throttle position sensor)?
accentstencil
71
It always starts with code 12 three times, then any other codes three times, then it ends with code 12 three times. Looks like the TPS could be your problem.
98vtberinla
40
gold coast
vt berlina
thats weird isnt it? if you get a code 12 wouldnt that come up alone with no other codes???
98vtberinla
40
gold coast
vt berlina
oh ok i see so its just code 19 what can i do with tps is there something i can do or do u just need to get a new one?
accentstencil
71
Check this attachment
