Results 1 to 23 of 23
Thread: VT Rear Camber Issues = FE2 Springs Require Camber Kit?
    VT
    May 2010
    Default VT Rear Camber Issues = FE2 Springs Require Camber Kit?
    Hi All
    I have searched high and low to find an answer but this is the best that I have come up with... Doesn't really answer my question.. vt needs a camber kit?????
    Anyway I have a 97 VT I have fitted some pedders springs that my mate gave me for free Anyway when I went and had it aligned I was told your tyres will be dead in about 5,000km if I don't get a camber kit as I currently have 3 degrees camber on the rear.
    This car is basically my interim car and I couldn't be bothered spending that sort of money on it, however at the same time I don't want to be replacing my tyres every 6 months or so..
    I have sourced some FE2 springs and I would like know if I fit them to the rear would I still need a camber kit? I have read the FE2 are about 30mm lower than standard, however not as low as the pedders (I think they are about 50mm) they will still ride a lot better than the stock springs that I am trying so hard to not have to put back in because they are awful!!
    Help is appreciated
    VXSS
    May 2007
    I own a ss with fe2 suspension and I am going to be getting the camber kit, as every 5000km I try to do a strip and fit on the rears to stop them weaing faster in the inner edge. It costs about $500 to get done at pedders.
    VT
    May 2010
    So really what you are saying from factory anything that came with FE2 and no rear camber adjustment will chew the inside of the tyres??
    Why Holden why??
    Anyway I would imagine that the FE2 would be an improvement over the stock suspension for handling and looks and also an improvement over the pedders in regards to tyre wear.
    I guess I will just stick with this compromise. I paid $750 for my car I am not going to spend $500 to install a few pieces of rubber and a few bolts just so I can adjust the suspension.
    At the end of the day I have been told even with the standard suspension it will wear the inners quicker becuase of the IRS there is nothing really you can do becuase when you accelerate the rear squats down.
    ve sv6
    Aug 2010
    VT
    May 2010
    At the moment I believe they are pedders superlow springs.
    I'm picking up the FE2 springs for the rear tonight so I will fit them and see how it goes. It won't take long to chuck them in and then I will get it checked at the local tyre shop to see howmany degrees of camber it ends up with.
    Is it 1-1.5 from factory?
    VX SS T56
    Feb 2006
    I removed my king lows in the rear and replaced with FE2 springs.
    I still put in a camber kit. Even with FE2 the rear end is a shit set up and it will wear the inner of the rears out.
    I used a super pro 4 point kit and it has been good so far >5000 kms.
    VX SS - Twin 2.5 cat back - MAFLESS Tune - MCAI
    VT Commodore Executive 9C1
    Aug 2009
    Croydon Hills, Victoria
    what size tyres have you got?? ive got 15's all round on fe2 and i dont have an issue, i have looked at 17's and definatly going to need a camber kit....and no i dont do burnouts with my 15's its a 9c1 and i cant afford the set of 17's i want....
    Growing Old is Mandatory...Growing Up is Optional!
    My Ride http://forums.justcommodores.com.au/...utive-9c1.html
    VT
    May 2010
    Really? Damm I don't want to have to fork out money for a camber kit maybe I will have to put the stock springs back in..
    I am running 17" clubsport wheels at the moment. I think they are 235x45x17 tyres..
    Aug 2009
    how much you want.....swap rims, im willing to spend the money on a camber kit!!! keep in mind tyres will cost you between $150 and $300 so times that by 2 and you get the cost of a camber kit in no time!
    VT
    May 2010
    Wollongong
    Aug 2009
    fitted i was quoted for a nothethane about 350, its worth it....plus you will be able to get it back if you convince some idiot kid who's just about to get his P's that its like awesome and fully sick!!!!
    VT SS S2 A4
    Aug 2005
    I run low king springs on mine without a camber kit, and the tyre wear is alot better than when I first got it with super lows in it. With the lows the wear looks fairly even.
    VT
    May 2010
    Well I fitted the FE2's to the rear tonight and I have it going to the shop it get it measured on Saturday to see what the rear camber is.
    Will let you all know what the outcome is.
    Edit here are some before an after photo's
    Pedders 2643 in the rear (This has 3 degrees cambers)
    FE2 Rear (Getting camber checked on Saturday)
    s1 vt
    Jul 2005
    Default camber
    some rear camber kits work others they are shit, i got the rear subframe from a vx series 2 installed which has the toe link controls and fixed the problem with kings lows
  15. #15
    VT
    May 2010
    Ok well it looks like I am back to the drawing board. Had the car checked out and it is at about -2.8ish it appears the springs have helped a bit however the tire shop said with the lager thicker wheels now it is putting more strain on the rear end and forcing more camber.
    Well I guess it's a camber kit or I will have to go buy some stock wheels and put the standard springs back in.. STUFF THAT!!
    I am looking at this kit of $155. 4 Point Camber Kit if this is the kit that I need then it seems pretty easy to do I would be able to fit that at home take a look at this thread for fitting. Rear Camber Kit fitting personally I wouldn't take the link off the end of the car to fit them as it would be way too much work you would be able to do it still on the car.
    What do people think of these kits.. I had a look at the kmac one fo $295 and well it is pretty much the same thing going by their photo all they do is give you tool to take the others out but why would you bother? You are not going to need them anymore so I would just hack them up so that you can pop them out easily.
  16. #16
    VT S-Pack S2
    Sep 2010
    I have this issue as well, iv got 18s on my S-Pack and i chew thru tyres like crazy iv been told i should get a camber kit but cbf atm as new 235/45/18s are only 110$ so its cheap to replace, or i just rotate them on a regular basis... good-luck find a solution mate
  17. #17
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Unfortunately for VT-VX1 owners this is always going to be a problem even on unmodified std cars and usually require fitment of some kind of camber kit if you want to save your tyres.
    The best solution as stated br Scrinky is the fitment of a later VX2-VY2 rear cradle with toe adjustment links.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
  18. #18
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Cheaper alternative is to put a VXII IRS setup on it with adjustable camber. Not as good as a camber kit but my car is on ultras and has done 10,000 and still good tread on my tires even after a few skids.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
  19. #19
    VT
    May 2010
    Bought myself a camber kit from egay for $160 I am going to fit it myself and then get it aligned so for around $200 hopfully the problem will be fixed.
    If not I will push the thing off a bloddy cliff.
  20. #20
    vt II s pack
    Jul 2009
    whats better to do get a vxII-vyII rear cradle with toe adjustment links fitted (also anyone know how much to get one and fitted?) or get a camber kit?
  21. #21
    VT V8 Calais
    Mar 2007
    Quote Originally Posted by sus_038 View Post
    What tyres are you getting at that price?
    50LTRv8
  22. #22
    JustDylan is offline Banned
    VN Berlina
    May 2010
  23. #23
    VT
    May 2010
    Quote Originally Posted by JustDylan View Post
    Slightly off topic but how did you pick that up for 750????
    haha it's not bad hey. It was my cousins car she is heading OS so they don't need it anymore.
  1. Non Lowered VT camber issues
    By Logz10 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-03-2008, 05:31 PM
  2. Camber issues
    By G4orce in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2007, 01:00 PM
  3. 4 king springs, shortened rear shocks, 4pt camber kit $490
    By Peasant in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-03-2007, 03:48 PM
  4. I need a good price for camber, springs, shocks
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2005, 08:29 PM
  5. FS: VX SS IRS FE2 Springs + Camber Kit
    By Raging Bull in forum Parts And Other Items For Sale
    Last Post: 11-10-2005, 01:22 PM
Tags for this Thread
