Have recently purchased VX LSD to replace my standard diff.
Before i start fitting it, can anyone give any advice or tips on what oils are best to use, will i need the additive, whats up with this allignment thing?
Have been reading a few other threads but haven't been able to get enough information.
Come on guys, surely someone's done this swap before
how much you pick one up for??
easy to install??
ask holden what they recomend.. then go from there.
cause my diff is getting clunky![]()
Id just read whats recomended for VX LSD diffs in the booklet at the shops or ask Holden.
I just did a search and come up with these, I didnt read thought it but it should have something useful.
VT LSD DIFF oil change
Diff oil for VZ LSD === GM Specification?
i had to put the additive in mine to stop the shudder at low speed/reverese(got from bursons) , and just lined it all up to all the old marks from old diff... 3 years later its still ok
also the top bolts are sooo bloody tight, so get a big mother ###er breaker bar or rattle gun with lots of bendy bits..
I was quoted today $800-$1000 just to swap over my standard vx diff to a vy lsd, i thought that was a ####in rip or is that a good price?????
Check out my ride here >>>>My VX Raptor
say NO to chev badges
Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
i got qutoed 2k for a lsd swap into my vt, that was drive in drive out job....
gee's, thats a definite rip.
jack stands are only $30 and it wouldnt take ya a day to do it ya self, its all pretty straight forward. undo bolts and put em back in. buy a gregorys manual for $30 if ya need, it has step by step instructions on everything....
even if ya get half way and get stuk ya can always get a mobile mach to come finish it..
its easy as just make sure you have the drive shaft that matches as the vt has universal joints and vx on wards has rubber mounts , so thats the only thing to look out for and you mite need a few high tennsile bolts that fit but its easy as .
just loosen the bolts at the diff from the drive shaft , drop the drive shaft loop , undo all bolts from drive shaft and take drive shaft away.
then take out the bolts from either side of the diff that go to the wheels , there is a little plug on both sides for the abs sensors ( or something else maybe but i think its the abs ).
then there is 4 big bolts holding the diff up so undo them ( depending on how u are doing it you need to have something stacked under it to hold the weight , makes it easier ) , And then once that is done and its dropping there is a little hose on the breather tube from the diff just slide that of and done .
do backwards to put new one in ( go buy $300 worth of tools etc if need be and if your not sure take pictures with a digital camera as you go so you know were everything goes . lots cheaper than $1000 and you will feel great driving it around knowing you installed it )
Getting the LSD in is no worries for me, it's this allignment thing people have talked off i'm concerned about.
Hopefully going to do it this weekend if i have free time. Got the new oil now, ready to go
say's in the manual just to match mark the diff and where it and everything sits before ya take it out (tail shaft to diff/diff to chassis/mounts/ect) just so ya can put it all back and line it all up in the exact same spot...... i just drew a line around the mounting plate of old diff (where it sits/bolts on to the chassis) and put the new diff in the exact same spot and it worked ok for me.
any one know the diff with a vt s1 diff to a s2 diff??
i know s1 run vs type and s2 has vx onwards, but whats rly different??
can u throw in s2 diffs by them selfs or do you need other parts as well???
S1 VT = BW78
S2 VT = BW80
diff, all you need to know
You would need to swap over the whole diff, the centres are not interchangeable from what I understand.
you can put a vx diff in vt or vt in vx you just need the same drive shaft as the diff you are putting in as the vx and vt have diffrent mounts for the drive shaft .
the vt has solid universal joints ( stronger but noiser ) the vx onwards has the rubber mounts ( makes nice and smooth )
dosn't really matter and i did my diff and no need for allignment or anything
ok thansk, il throw up a new thread insted of taking this one
All done. Half a days work in the home garage under axle stands.
Hardest part was loosening the front two diff mount bolts as they are a little hard to get at and won't accept a socket. Otherwise the swap is simple as.
Put a V8 SS LSD in, the 3.07 gears don't really affect the speedo much. Checked its accuracy with the GPS.
Took it for a fang after and couldn't believe the extra traction i had (even though it was raining also).
So out with the noisy old single spinner and in with the LSD. Unfortunately i found two other jobs that need doing now
i hope this is the same for me when i try putting a vy ss lsd in my vx, lets hope so
