Results 1 to 12 of 12
Thread: Help Installing a Boost Gauge on vx supercharged 6
    VX SUPERCHARED S s2
    Dec 2006
    Default Help Installing a Boost Gauge on vx supercharged 6
    Can Anyone help me with were the hose from the boost gauge connects to the supercharger.
    VT Calias S/C Series 1
    Aug 2006
    Outer SE Melbourne
    Default Boost gauge connection
    On the passenger side of the supercharger, under the plastic cover there are some small plastic hoses towards the rear of the supercharger, they have rubber boots on the end of them, one connects to an actuator valve that connects to the supercharger. This hose is the one you want. It is the bypass actuator for the supercharger and it gets a feed from the manifold. If you need a photo i can supply one but it will be a pain in the but as i will have to go pull my cover off and take one for you.
    Hope this helps, Andrew
    2x VS
    Jul 2005
    Disclaimer For The Reader ::
    The information I provide is freely given to ONLY help you with thinking on problem solutions. IT IS NOT a "How To Do It Guide".
    If you read ANY of my supplied information and use ANY of it you must accept and agree to do so AT YOUR OWN RISK
    or do not use the information at all
    I accept NO liability if you damage your or anyone elses property or cause any harm to yourself or others with the information provided.
    I am NOT a Mechanic. You have been warned.
    mcgyvah is offline try it & see
    stock Supercharged VT S series I
    Jan 2007
    Tynuts, Just wondering if the bypass hose worked.
    I thought this actuator operated under vacuum? (please be nice I am easily misled)
    Jan 2007
    as i have been impatiently awaiting a reply to this thread for a whole hour...
    I decided to tee off this bypass actuator hose and fit my gauge and see what happened.
    It read a nice vacuum at idle , and ,when I temporarily taped my guage to my bonnet and went for a drive it manage to just nudge the positive about 0.1PSI at full acceleration to redline in 1st and 2nd.
    I thought i might try attaching it to the manifold as is also suggested.
    Any idea how to get that rubber plug in the manifold off without breaking it? as I will likely need to put it back.
    Vt II supercharged
    Jul 2005
    Jan 2007
    thanks for the pics,
    is that the your boost gauge coming of the white nylon tee?
    I put the tee in the hose above this which goes between the sc and the actuator, maybe i used the wrong hose?
    sixshooter... i haven't found that m90 webpage yet, i'll look somemore tomorrow.
    2004 VY2 SV8 A4
    Jun 2005
    Victoria Point, Brisbane
    It is very easy to use the vacuum nipple on the front of the manifold. That is where mine is attached. I found that the plastic cap broke when I took mine off, as they all go brittle with age anyway. Just attach a bit of hose to it and fold it over on the end and clamp with a cable tie if you arent ready to install the gauge yet.
    * Phreddy's Blaupunkt Aux input and line out mod
    * 18x8 inch Equus Kalibur Wheels with Maxxis MAV-1 235/40R18
    * Sureflo 3.5 inch medium-loud cat back exhaust
    ford
    May 2005
    in a ford
    i used the vacuum line on the front as shaggerz said, it gives me an accurate reading, & is easy to fit, although dont be suprised if the black rubber cap breaks when you pull it off, mine did, if you need pics, just ask i will post some for you
    Vt II supercharged
    Jul 2005
    Quote Originally Posted by mcgyvah View Post
    Yeh the white tube going to the back of the engine is to the back of the boost gauge the tea piece came with the boost gauge (Autometer)
    scbh81's Avatar
    scbh81 is offline VRUUUM XU6 180 SC
    HSV XU6 VTII 99
    Jul 2005
    St Kilda Victoria
    Quote Originally Posted by Charg'd View Post
    yeah mate some pics would be great!!!!!!!!!!
    There is no such thing as 'What if?'
    http://forums.justcommodores.com.au/...y-hsv-xu6.html
    VT S-Pack 3.8L Supercharged - Rebuilt*
    Feb 2010
    If you have a valid reason for requiring my location, you can ask!
    ye i'd like to know too coz i'll be putting one in mine. but which gives a better reading? the tube from the actuator or the one on the front of the supercharger?
  1. boost gauge
    By vs_commodore_s in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-10-2007, 12:18 PM
  2. boost gauge
    By 10000_fists in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-05-2007, 02:29 PM
  3. Boost Gauge
    By XXFR in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-04-2007, 01:02 PM
  4. Boost Gauge
    By XU6 (fLOGINU) in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-01-2006, 05:40 PM
  5. Wtb:- Boost Gauge
    By V6VL in forum Swap / Wanted to Buy / Trade
    Last Post: 06-05-2005, 01:22 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
