As the title states, anyone done this in a VT? Wanna change the trim on my seat so need to remove the entire back seat. How hard was it? Any tips or pointer as to where all the screws/clips are located? Cheers
umm haven't done this in a couple of years, but from memory there is a couple of handles type things u find just under the bottom cushion, you need to grab onto these and pull the cushion out, its easy. Then once the bottom cushion is out you will can easily seen the bolts for the back cushion, undo these and lift the back cushions up and off. Sorry the instructions are a bit vague, but its been a while.
Not sure of VT, but I've got a VR - can't see that they would be too much different.
There should be two clips under the seat near the front of the seat. You just have to push the base of the seat towards the back of the car with a bit of force then lift it up and take it out.
