Results 1 to 5 of 5
Thread: Hand Brake Adjustment
    Dec 2009
    Default Hand Brake Adjustment
    I want to check the adjustment of my VY's handbrake. Does anyone know how many clicks or how far the lever should come up?
    The manual I have mentions something about measuring accross the park brake shoes with the rear disks removed but it is one of those Haynes manuals which is a mix match from VT to VY and I think it may be wrong for the VY as it mentions shoes and I am sure the VY has a hoop like 1 piece shoe.
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    VY handbrake Try this method, I can elaborate if you need it.
    Dec 2009
    Quote Originally Posted by VYMAD View Post
    When yours is adjusted up properly how far does the lever pull up?
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Aah about 4-5 clicks roughly.
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Quote Originally Posted by wortus View Post
    Hi Wortus
    You're right about the VY handbrake mechanism - it has a hoop that I believe cannot be adjusted. I tried some months ago but the "adjuster" has no thread - it just acts as a "filler" to connect the two ends of the hoop. I guess all adjustment has to be handled by the lever and cables. As said above, about four to five clicks is what you are seeking.
  1. Adjusting Hand Brake shoes ( disc brake )
    By Fusion in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-06-2010, 01:35 PM
  2. VS ute rear Brake Proportioning valve adjustment
    By MYVESSV8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-05-2010, 05:20 PM
  3. ve hand brake adjustment
    By joesoquick in forum VE Holden Commodore (2006 - ?)
    Last Post: 29-10-2009, 06:15 PM
  4. hand brake adjustment???
    By hbdvysute in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-09-2008, 10:15 AM
  5. VY Hand brake adjustment
    By R-ON in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-09-2006, 08:50 PM
