Results 1 to 4 of 4
Thread: blue light conversion in vz ssz ute
    vz ssz silver ute
    Feb 2010
    perth WA
    Default blue light conversion in vz ssz ute
    hey all jw if people could post up some pictures if they have any or point me in the right direction i wanna change all my green lights to blue is it easy to do myself or should i take it to an auto sparky
    My vz ssz ute
    THOSE WHO CRITICIZE OUR GENERATION FORGET WHO RAISED IT
    VY SS UTE
    Jun 2009
    Mandurah, WA
    seriously dude all you needed to do was do a search
    ASR Work Examples and Pictures
    go to ^^that^^ link and have a look. this work is done by phreddy at ars audio ask him all you questions
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    M'mmm, for road use and to save you future embarrassment and possibly defect I suggest that you retain red lights at the rear and white lights at the front. Anything else will.....?????
    Motor vehicles have been required to comply with Australian Design Rules (ADR's) for lighting since October 1991. ADR 13 mandates the number and position of lamp assemblies, ADR 46 prescribes the photometric requirements of the lamp itself and ADR 51 is the standard for filament bulbs.
    ADR 51 accepts ECE regulation 37 as an alternative standard for filament bulbs and prescribes the dimensional and photometric requirements for filament bulbs (including headlamps). This ensures inter-changeability and correct functioning when installed in a complying lamp unit.
    All complying bulbs sold in Australia would be marked with the "E" mark and possibly the words "Suitable for European Use". The packaging may also indicate compliance with ADR 51 or ECE 37.
    When a replacement complying bulb of the correct type (for example H4 45/60 Watts) for a complying headlamp is fitted to that assembly, the light emitted will be within the spectral requirements for white light. This will not be in breach of Section 63 to Schedule 1 of the Transport Operations (Road Use Management- Vehicle Safety and Standards) Regulation 1999.
    Although these lamps are a standard fitment to many newer vehicles, a "blue" complying lamp can be fitted to a lamp assembly on a vehicle that was not originally fitted with these bulbs.
    It is important to note that ADR 51 limits the power of various bulb types, and bulbs of a similar style but higher power rating will not comply and should not be used. For example, the common H4 bulb that has a complying rating of 45/60 watts, is available in much higher rating of 45/100 watts. The higher powered bulbs produce more glare and the resulting light pattern would not comply with the ADR.
    Although regulations do not require drivers of pre-1991 vehicles to fit complying bulbs, consumers should be careful when fitting non-complying "blue" light bulbs to pre-ADR vehicles, as the resulting light spectrum may fall outside the standard for white light (that is, the blue frequencies may predominate).
    If a Licenced Examiner suspects that the light output from a headlight appears blue, the examiner should take appropriate action based on the following summary tables:
    For vehicles manufactured on or after 1 October 1991
    • Bulb must be marked.
    • Bulb must be the correct wattage.
    For vehicles manufactured prior to 1 October 1991
    • Bulb does not have to be marked.
    • Bulb may be alternative higher wattage.
    • Bulb must not show obvious blue light (when viewed directly ahead).
    Licenced Examiners Action:
    If, during the course of an inspection, Licenced Examiners have cause to inspect vehicles modified by changing the original lighting componentry assemblies, they are to ensure that individual vehicles comply with the previously mentioned details. Modifications of this type
    which do not comply with the above requirements are to be rejected immediately.
    tim005's Avatar
    tim005 is offline Yet Another VS Ute Owner
    99' Series 3 VS S-Pac Ute.
    Feb 2009
    Melbourne.
    i think he is talking about interior lights mate, hence the changing the lights from green to blue....
    http://forums.justcommodores.com.au/...first-car.html My VS Ute, 99', S Pac, 5 Speed.
    Quote Originally Posted by maldotcom2 View Post
    Also, always go into a corner in second gear in case you see a hot chick or another commodore you can fang it out sideways.
LinkBacks (?)
  1. VT blue dash conversion
    By phatvtcom in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2010, 07:47 PM
  2. blue dash conversion help
    By richardpalinkas in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-01-2010, 04:15 PM
  3. VY II SS Blue conversion
    By Skooby in forum ASR Audio & Electronics
    Last Post: 12-05-2009, 11:27 AM
  4. BLUE LED Dash Conversion
    By scbh81 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-01-2008, 09:55 PM
  5. Blue 202 to LPG conversion.
    By spd_dmn in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-10-2006, 12:17 PM
