B3924 = theft deterent start disable signal recieved
P1678 = immobilizer powertrain id failed
P0102 = air flow circuit low input
P0700 = transmission control module
P1632 = torque converter clutch
P0741 = wrong environ id received
these are my codes what do they mean exactally, why do they come up? with the transmission ones would that have anything to do with the 3500 stall converter not known,
and I have at times turned the igniton to were it comes up as immobilzer fail then turn key off and try again then it starts but it does it every now and again what causes it, any1 have these issues at all ?
VZSSCHASE 2677615 said:thanks mate for your input,yes I have installed a non-lockup hi stall converter to meet with my upgrades eg, cam and etc.., and my mechanic has tuned and adjusted shift points to maintain the right driveabilty and being a non lock converter I tend to chew the juice.will replacing the key and coding a new one fix the immobilizer problem?as for the air flow that's always been there since I had the car but never brought up the powertrain light.
