Results 1 to 4 of 4
Thread: Limp Mode
    LX6 Adventra
    Jun 2005
    Default Limp Mode
    Hi All
    Has anyone had the 190kw motor go into limp mode (not sure if that’s the right terminology)?? On the open road at the weekend I went to overtake and the car went from 5th back to 3rd gear as normal, on the shift into forth the gearbox made a loud clunk and ESP fail came up on the dash as well as putting the car into limp mode. I made it to the next town and found at low speed the brakes were grabbing without me applying them. I called Holden Customer Care who sent out the NRMA who proceeded to disconnect the battery to reset the system so I could continue my trip. I returned the car to my dealer yesterday only to find that the error codes were no longer there as the battery had been disconnected.
    I cannot make the car fail again and now don’t feel comfortable when overtaking. Has anyone had a similar problem???
    Burnout_bro's Avatar
    Burnout_bro is offline Donating Member
    HYPER VX SS/ R33 GTST
    Dec 2006
    did you disconnect the battery at any time before you had this problem? if so your ecu needed too reset itself, if you ever remove a lead from the battery, turn your ignition all the way up (before you start the car) put in every gear for about 20 seconds then put back in park and turn on the car, rev at around 2500rpm for 20 seconds and you are right too go.
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    i would say its some rare niggling problem with the computer management, holden's still hasn't got all the bugs fixed yet, i'd just take it easy and see how it goes
    We got rep back, yaaay!
  1. Limp Mode
    By martrogers in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-10-2007, 08:18 AM
  2. limp home mode
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-07-2006, 04:56 AM
  3. limp home mode
    Last Post: 24-11-2005, 09:17 AM
  4. Turning off limp mode?
    By garfa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-09-2005, 05:36 PM
  5. ecu still in limp mode
    By Juzzy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-09-2005, 04:51 PM
