Results 1 to 12 of 12
Thread: VZ cooling system.
    Jul 2006
    Default VZ cooling system.
    People.
    I've got VZ 05 that ive just noticed has soft radiator hoses after driving like there is no pressure in the system.
    No overheating, level in overflow tank ok. Let it idle for a while, fan comes on as necessary and turns off as req, temp gauge @ 1/4..
    Had this with my VT. was a crook Radiator cap but that was losing coolant. The VZ isn't... Just had a 67500K service done a couple of weeks ago.
    Air in the system possibly ?? Any ideas???
    Cheers.
    Vin
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Orange, NSW
    i think it occurs from the style of radiator cap and is fine, mine does it to, if you look at the cap its like a plunger as most are but pretty reactive to pressure, also the the cap being where it is, is at the highest point of the cooling system so bleeding isnt neccessary, but i think there is a screw on the top of the radiator....have to confirm that
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    05 VZ Commodore Equipe
    May 2007
    Andyman is right, the air bleed screw is on the left side (as you look at the motor) up the top of the radiator.
    Heres a few good points about general cooling systems
    Coolant Hose
    andyman's Avatar
    Mar 2005
    Orange, NSW
    Quote Originally Posted by IPCOlsenVZ View Post
    Coolant Hose
    good link ipcolsen
    Jul 2006
    Cheers guys...
    You'd have 2 wonder why u need a 2nd bleed point if the cap is at the highest point.
    I ran it again this arvo and found no air when removing the cap. Let it heat up and this time built up pressure before kick in of fan. When fan shut off pressure was again gone... Must be a very efficient cooling system on the alloytec compared to the ecotec. Shame about where they put the thermostat(rear of engine). my wife's VZ crapped one. The repairer had to remove the inlet manifold to access the housing. about 5 hrs work... lucky was under warranty.
    Be honest i've not been happy with my VZ. Diff problems A/C problems fuel gauge problems, ABS light problems, ESP light problems..... List goes on. I guess you get what you pay for... Goes ok though
    Thanx again guys
    Vin
    andyman's Avatar
    Mar 2005
    Orange, NSW
    Quote Originally Posted by vinnycol View Post
    Thanx again guys
    Vin
    yeah thats the problem with mass produced cars, built quick at a price to sell, im lucky enough to not have a single problem with mine,
    oh and diff problems are standard from when they first introduced them in the vt's, i just used it as an excuse to upgrade to a lsd 3.46:1 ratio
    vz police executive
    Oct 2008
    Default vz cooling
    my vz thermo fans rarely cut in. i have allready had the cooling system die once and the temp gage didnt budge over 1/4 but i heard it boiling. what the bloody hell is going on. the alloytec engine is ****house
    andyman's Avatar
    Mar 2005
    Orange, NSW
    is the cooling system bleed properly? there is a screw on the top of the radiator, if you go into the mode+set turning ignition on menu, what does the coolant temp get to? try swapping the thermo fan relays with another one in the relay box
    vz executive
    Feb 2010
    05 VZ Berlina
    Mar 2010
    One of the first things I noticed when I got my VZ was the lack of pressurising of the hoses and the coolant wouldn't stay full.
    Changed the rad cap with a $13 one (CPC) from supercheap and now it's fixed.
    http://www.cpcauto.com.au/radiator_c...PartNo=570-120
    I think the old one was letting coolant expand out but not suck it back in.
    The next day I noticed on the old cap the plunger just fell off the spring!
    now : 05 VZ Berlina V6
    had : 97 VT Berlina V6
    before : 81 VH SL/E I6
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    ^^^Yeah the rubber doesnt seem to last very long, i had a similiar issue with mine.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    VZ Equipe wagon
    May 2009
    Quote Originally Posted by andyman View Post
    I just replaced the heater tap on my VZ V6 172kW, do I need to bleed the cooling system?
  1. My Cooling System... Help
    By Explosions Hurt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-04-2008, 08:03 PM
  2. V6 Cooling System
    By tja_bot in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-03-2007, 12:27 PM
  3. cooling system
    By Dayvo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-05-2006, 10:52 PM
  4. VT Cooling System
    By MySV6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-05-2005, 03:11 PM
  5. Oil in the cooling system?
    By portercg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-12-2004, 10:43 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
