pft there's no way i'll ever video it, you gotta be an idiot to video that while your driving. I got VCM Scans ........ but it doesn't measure in exact milliseconds.
To be quite honest lets weigh it up. The VZ's suck overall........ their fuel injected, the throttle is hopeless and choppy which is also a reason for knock, the execs have fairly limited 4 speeds and the sv6's have a crappy beamer gearbox not designed to deal with more torque then what they put out stock. The stock intake is woful and could of been designed way better, the gear ratio on the diff is crap stock........ I mean really. The only good thing about the VZ's are they are brutal with torque with their cam setups........
The early model VE's are pretty good, again tho fuel injected....... mildly fixed the intake, the diff, the throttle........ but due to their difference in cam setup they cause the inlet penum to run hotter then a VZ by an average of around 6-10 degree's, their heavier.......... our manifolds in the VZ's actually get cold at night, the VE's dont so much.......... but perhaps thy are designed that way for a reason.
The VE's are better overall off the line due to their cam run up........ which gives nice power off the line to the limiter......... nothing magic but focused on getting the power to the ground more on VE's......... and there's also no stupid VE table, the cars ECU works that out for you based on your tuning parameters etc.....
To be quite honest.......... I think the SIDI is the bomb...... both the Omega and SV6, better gear ratio's, more gears = more power per gear, no fuel injector lag which is damn annoying....... direct injection is WAY more accurate so there's less variance in power on a hot day compared to a cold night.....
Personally I think the alloytech engine overall is the bomb, there's no much you can do with it......... I'd love to see a twin turbo V6 sidi or a V8 version of the alloytech engine.......
But yeh 0-100........ 6 seconds done with the right tune....... so far only a 06 VZ Exec out of my tunes has been able to hit the mark, 05's......... utes, CTS, SV6 etc will run just over a 7.........
Also I personally dont care as much about 0-100......... but it's HARDER to get the power interval sorted into gear changes, so eg.......... if I'm at 55km/h and floor it, it'll run upto 6000rpm roughly and shoot from first gear.......... too much torque in alot of the tunes = no grunt, lower torque, more spark and a build = a bang.......
There's more then just foot to the floor.......... no good if someone rolls up beside you and guns it and you floor it, hit a weak spot n get owned. SV6's have less of a problem on that one having the extra gear mind you. 4 speed gear boxes unforunately get trapped by that. I'd never get a auto sv8 etc........ 4 speed with v8 powers is like constipation
6 speed manual sure but again......... VE's are better overall.
