19" or 20" Walkinshaw wheels on VL Calais
HsvR86.2
L67 Vy
Hi All,
Just wondering if we can put up some pics of 19" or 20" Walkinshaw wheels on VL Calais.
Please inform about pros and cons.
TIA
Commo64
2010 VE Omega
19" Walkies
20" Walkies
keith reed
76
Raceview Qld
1983 vh v8 sle 2000 vs v8 ute 2012 ve11 redline
One the ride will be harder, two the tyres will be dearer and three more chance of damaged rims.
Commo64
2010 VE Omega
If you want "in your face looks", go for the 20's, however if you want a little more usability, go for the 19's... In saying that, both of these wheels are huge for a VL and they will both a provide harsh ride and will get curbed easily...
apollo13
FIFO
VE LPG
You will be struggling to get correct rolling radius with 20 inch. And you will have to consider the tyre load rating as well when you get down to tiny sidewalls.
Ginger Beer
Dunnydoore
Is it a street car?
Will you be doing alot of cruising?
Is 17-18" an option?
If so, I say 17" if you want to actually drive your car around with good compliance
Plus 17" tyres are much cheaper and you can actually get "good" rubber at a reasonable price
Disclaimer: for any cruiser that will actually see some Hwy and country roads 17" is the biggest I would ever go
#sidewall
vc commodore
Like the Leyland Brothers
VC, VH and VY
Easy enough to get the correct load (92 minimum for a VL from memory...Might even be 94) and rolling radius is easy enough too....
245/35X20 is the common fitament
Here's a real cheapie, with a 95 load rating (above what is required).....
https://www.tyroola.com.au/v1-winru...MIyrS8tvvRgQMVWaZmAh1ZWArsEAQYASABEgJ4vfD_BwE
Ride, well that's something else
